Santi's Slick 66 F100 Project
Anthony
Post by Anthony »
Nice, Very nice. Looking good Santi....
Paranoid!
Drop
Post by Paranoid! »
Great!!!
Looking good!!!! :D
Thanks for the info on the install also...Will be waiting for the motor drop to see how she sits!!
I think I'll drop my front 1st to see if I want to lower the rear?? :?
Found a place today to buy all that I need for the cab mounts off a 79!!!
for $20.00 hope the floors are good....I'll cut both out in 2 shots..
And also get the discs if available.....
Again...Good job!!!
I thought I was wrong once...
Turned out I was right!!
Russell
Santi
Bed is finally off!
Post by Santi »
I finally got a little more work done as I have been traveling for work and was away for a while. I got the bed off and as you can see I lucked out and don't have much, if any, rust underneath. Man I wish I would have done this in the beginning before installing the lowering kit in the rear..lol..I do have a little rust under the cab but very minor. I will show those later as I get to that point. Now I need to figure out how to lift my cab high enough to roll the frame out. Since I'm working in my 2 car garage things aren't easy with out all the high tech stuff needed. Oh well, guess thats what makes this fun.. Next step: hopefully sandblasting frame.
Also, thanks for all the positive feedback. I appreciate it.
Anthony
Post by Anthony »
looks nice and solid and those cab corners look great!! 8) Keep up the work and keep those pics coming....
kstones63
Post by kstones63 »
The cab is pretty easy to get off if you have access to an engine hoist. Bolt a chain down at the seat bracket bolts and lift the cab off with an engine hoist. It is front haevy but 2 extra people can easily balance it to take it off. I put mine back on this way and it went real well.
Keep the pics coming.
KEvin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
Rusty 63
Post by Rusty 63 »
Some guys just lay the cab down on its back onto the frame & work on it like that. In another thread I read a guy weighed his bare cab at only 325 lbs, so if you had three helpers, you shouldn't break a sweat lifting it up & walking it off.
Or if you do have access to a hoist, try this (as posted in the Truck Talk Section - "Show us Your Cab Dollies"
(Edit - link to the Thread - scroll down til you get to his post)
http://www.fordtruk.com/forums/viewtopic.php?t=16253
f100jim
PostPosted: May 7, 2010, 3:42 pm Post subject: Reply with quote
Engine hoist with a piece of angle. Easy about lifting cab off and on frame by yourself.Image 7570
_________________
65 red&white custom cab. 65 caribbean torqouise [blue green]
Santi
Post by Santi »
Sweet... thanks a lot.. I will see which one will work best for my garage.
Rusty 63
Post by Rusty 63 »
Yeah, the dollies are great, but I was trying to show you the post by f100jim where he showed lifting the cab off the frame with an engine hoist. But whereas most do it with chains (which leaves you to try to balance a 300-400 lb pendulum), he used a piece of angle to run through each door jamb. I'd hazard to say that with w pieces of 2x2 angle on each side of the average 2x2 square tube on a cherry picker, you'd end up with a much more stable 6"(+) wide surface to support the cab. Sounds a bit easier to balance, at least to me. Good luck & let us know what you come up with!
Santi
Cab is off!
Post by Santi »
I got the cab off today.. hopefully I can get the frame to the sandblaster this weekend. Here's a few pics of how I used the engine hoist and somehow still got everything to fit in the garage...lol..
Image Image Image Image Image
Rusty 63
Post by Rusty 63 »
OUCH! I went to look at a donor cab - the guy used a big tie down strap (he didn't use a blanket like you did) and he went thru the open windows... bent the tops of the doors and the drip rails.
Hope your rails are still good!
If so, darn impressive!
Looking good - keep up the progress!
Santi
Post by Santi »
LOL... Yeah they are still good. I was making sure as I was lifting it and putting it down. I layed it down so there's no stress on it now so it should be ok. Thanks for the heads up. 8)
Santi
Update
Post by Santi »
So I just wanted to give an update for those that even care..lol
After I tried lining up the new power steering box from the donor, things were not lining up. After doing more research and rechecking things, I realized my damn I-beams were in backwards.. bang.gif
The only good thing about it was that I have to take everything off again anyway because I decided I'm gonna prep my frame. I ordered the rust encapsulator and chassis paint so as soon as I have more pics I will post them. Thanks for reading.
Anthony
Post by Anthony »
Hey Santi, Why just do it once??? if you do it 2 or 3 times you will become proficient at it. Or at least that is my story and I am sticking to it... :lol:
I.E.
Posted: Sat May 15, 2010 10:17 pm Post subject:
not much but I am making progress... passenger side rotor put on, moved to drivers side and put rotor on, had to take it back off to start putting brakes on, got the bracket put on and assembled the hub again, couldn't get the pads in so I had to take it apart a third time.... Sound like a theme here??? finally got the drivers side done and went to put the new brake hose on.... of course it was the wrong one... any way, to make the story short.... I only had to take the passenger side apart one more time to get the brakes done on it...
If you didn't know any better, you would think that I enjoy doing things multiple times... :hm: I am pretty sure that I don't, it just rolls that way with me...
Your build is coming together nicely and the cab removal looks like it went smooth... Keep up the work and keep sending us those pics... :thumright:
Santi
Post by Santi »
Well I got everything off and almost ready for the Rust Encapsulator and then painting. I decided to skip the sandblaster and do it myself (What kind of build would this be if I sent it off and didn't do things on my own right?)
For those of you that think you need to take the frame to the sandblaster- if you got the time you can use a sander, a wire brush, and a wire wheel and you should be good unless your frame is really bad. Also, I have a compressor so it helped out with the wire wheel instead of eating up my batteries on my drills (which I did until I realized I should use my compressor..lol). Did I mention only if you got time? :lol:
Here it is almost done. I should have the Eastwood products in on Saturday so we'll see how quick I can paint it.
Santi
Got the Rust Converter on..
Post by Santi »
Well I got the Rust Converter on.. Man what a difference...
I even got the wife to help me brush the entire frame..lol.. Now I gotta let it sit 48 hours then I can spray the Encapsulator and then paint it..
Before Rust Converter
Wife helping
After Rust Converter
I will post more pics as I go.. Thanks for looking.
1965fordf100
Post by 1965fordf100 »
Looks good, Santi! I used the same stuff from Eastwood, it works great, I'm happy with the results so far...
Phil
Anthony
Post by Anthony »
looking good Santi... It is always nice to have help... keep up the progress and keep us posted, can't wait to see it done!!
Rusty 63
Post by Rusty 63 »
Good job! My wife won't come out in the garage except to take the dogs out!
slickmainer
Post by slickmainer »
did you do prep sanding on the frame or just use the converter?
--Gregg--
you can't get there from here
Santi
Post by Santi »
I prep sanded most of it.. and also used a wire brush for the stuff I could not get to.
