Posi rear end????
Paranoid!
Post by Paranoid! »
I think Iv'e got!! :D
Thanks for all the help people!!
Barnietrk......
I was wanting to know which traction lock pig would fit my differential and how to identify it...
Thanks again everybody!!!
I thought I was wrong once...
Turned out I was right!!
Russell
BarnieTrk
Post by BarnieTrk »
Russell,
Ok, so it sounds like you're just looking to replace the Ford 9" center carrier with one that contains a traction lock differential. Be aware that differentials that were OE-installed behind a high performance engine or a big-block may likely also have gotten 31-spline axles, which means 31-spline differential side gears. Obviously, 31-spline side gears will NOT work with your 28-spline axles.
Locating a center carrier with a 28-spline traction lock differential may be a tough character to locate (I know it would be around these parts), but there may still be some out there - somewhere.
Good Luck & keep us posted on your progress!
BarnieTrk 8)
Paranoid!
Post by Paranoid! »
BarnieTRK....
Thanks for that one....
If I come accross that problem, Ill just buy the whole dam thing.....
From the sounds of it, If I find either one "28 or 31" I better snag it....
Russell
