Replacing Old M/C with Dual M/C w/stock brakes
blackagatha
Post by blackagatha »
62galxe wrote:you could use the other hole for the brake switch. :shock:
..... I request that you undo that monkey-a$$ setup.
the one with the cut off line hanging out too.
I'm sorry but it looks like a bad idea man.... in a bad kind of way. It's freakin easy to split the brakes.
62galxe
Post by 62galxe »
The first pik was a joke. i saw it at a car show. if your refering to the cut off line on my truk pik its because its not finished. I was just showing how i mounted my brake light switch. hope this satisfies your request.
1963 uni PATINA BLUE
1965 short bed
blackagatha
thank you sir!
lmao. I would hope that nobody HERE would be dumb enough to pull something like that, but alas, people do it
Hawkrod
Post by Hawkrod »
62galxe wrote: The first pik was a joke. i saw it at a car show. if your refering to the cut off line on my truk pik its because its not finished. I was just showing how i mounted my brake light switch. hope this satisfies your request.
While the brake line situation has been explained, I don't see any comment or explanation for the soft copper fuel line. There is definitely a reason it is illegal in most states. That is about as dangerous a thing as you can do on an old vehicle. If you still have a copper line for fuel then you need to change it ASAP for your safety and the safety of others. Hawkrod
blackagatha
wow never even thought about copper. I wonder about aluminum lines like they use in airplanes. probably even worse.
cars2cool
Post by cars2cool »
Blackagatha - Plumbing lines on aircraft are stainless steel.
'31 Model A pickup, '55 F100 Yblock w/fordamatic, '56 F100 6cyl. 3 spd. BBW my first pickup bought when I was 13 in 1974, '77 Lincoln Town Car with 64,000 original miles For Sale
Riverside Racer
Post by Riverside Racer »
I'm mounting a '70 F100 Dual master cylinder on my '66. I'm lost on mounting the brake light pressure switch.
I would like a simple T like on 62galxe's picture but the center tap is another compression fitting not pipe like the switch.
Any help would be appreciated.
66 F-100, Short Bed Styleside, 352 V8 Auto Trans
62galxe
Post by 62galxe »
they sell the adapter tees. inverted flare ends female pipe center port.
http://www.speedwaymotors.com/IFF-Brass ... ,6467.html
1965 short bed
DV65CustomCab
Post by DV65CustomCab »
Pegasus Racing Supplies I believe sells the correct part also. They've got a lot of cool custom stuff like that.
Stop The Longbed Hate! :)
Now: '93 F150 Lightning
62galxe
Post by 62galxe »
Im planning on changing mine up. The tee is going away. Im looking at using bajo to inverted flare adapters. I am going to drill and tap one of the banjo bolts for the pressure switch. I think it will be a cleaner looking setup.
http://www.purechoicemotorsports.com/in ... prd107.htm
1965 short bed
Riverside Racer
Thanks for the help.
I drilled and tapped the center if the IFF Tee to 1/8" pipe and lengthened the MC pushrod 3/4" all is good now.
I like the banjo fittings! I'm happy with what I have. Maybe I'll go banjo when I install power disc's and a the 392 Hemi....
