New member
BarnieTrk
Post by BarnieTrk »
hotrodz&banjos wrote:great info guys, goin by the charts its an fmx. can you guys give me any info on the fmx transmission, is it good , bad , etc. any problems bolting my 351 windsor to it ? didnt mean to take over this post, just lookin for information. thanx.
If the automatic transmission under your '66 F100 is original, then I'd say it is likely a Cruise-O-Matic (COM) transmission.
Although they were of the same transmission family and shared the same pan, the FMX was a different unit.
I believe the FMX transmissions came out later, like '68/69. I know FoMoCo put the FMX behind the new-for-1969 351-Windsor engines.
I don't know if an earlier '66 COM transmissions would bolt to a '69+ 351W or not.
The FMX is not a popular transmission to hop up, like the C4s and the C6s, but the fMX was put into the '69 Mustang Mach I, so it could take some thrashing.... :wink:
One way to tell a COM is that the early Cruise-O-matics had a filler tube that attached to the transmission pan.
Whereas the FMX transmissions filler tube slid into the main case. An automatic trans expert I'm not.......:2cents:
Good Luck!
BarnieTrk 8)
