Thank you everyone for the comments! The feedback is good to have, and it's inspiring.
Alan, fellow Cleveland fan (351 Cleveland - not the Cleveland Browns or Cavaliers), I was going to move on to the engine assembly, but I've decided to spend the winter smoothing the body and fixing some rust. Also getting the inside of the cab done, wiring fixed up, brakes plumbed, etc. Then when the warmer weather returns I can finish cleaning the rest of the engine parts - oil pan, timing cover, etc. I can take a few shots of the block and all the pieces for you???
I want to be ready to fire the engine as soon as it's assembled and dropped in. Everything for the Cleveland is ready, though. The block has been cleaned, bored .03 over, new cam bearings, freeze plugs. The heads have been redone, the pistons are on the re-sized rods, crank ground .10/.10.
I have an Edelbrock Performer intake, Holley 600 carb, a set of headers (don't know what they were made for but they fit) and an HEI distributor (GM HEI design - but it's on a 460/Cleveland housing).
I had the Celveland given to me. A friend had it disassembled in his shed, and when he moved, he didn't want to take it with him. So I had the engine way before I got the truck. I think it came out of a '73 Torino. It appeared to have had an easy life, or it had low miles.
Another thing - I am considering running this on propane or natural gas in the future.
I've got some pics of the body work I've started, so I'll try to get this posting up to date.
I bought some sand yesterday to blast some areas on the body, but I saw on the bags it says "DO NOT USE FOR SANDBLASTING" What???
So I guess I wont do that today.......
