Posted: January 17, 2011, 9:49 pm
what is the purpose of those tubes? it seems like they just redirect a lot of the oil back to the pan. i would like to block them off and keep that oil up top.
The tubes help to ensure that oil gets to the timing gears and distributor gear. People have run without them and with the hole plugged and those components seem to get adequate oil. The distributor gear sill gets a lot of oil from the valley, anyway. Those tubes also prevent the shaft from rotating. If you remove them, you will have to install screws, in their place, a 1/4" tap works to cut the threads, and make sure that the screws engage the shaft to prevent it from rotating. If it rotates, your supply can be completely cut off.ezernut9mm wrote:what is the purpose of those tubes? it seems like they just redirect a lot of the oil back to the pan. i would like to block them off and keep that oil up top.
That's what she said!charliemccraney wrote:As long as each rocker is wet, you should be good.
charliemccraney wrote:The tubes help to ensure that oil gets to the timing gears and distributor gear. People have run without them and with the hole plugged and those components seem to get adequate oil. The distributor gear sill gets a lot of oil from the valley, anyway. Those tubes also prevent the shaft from rotating. If you remove them, you will have to install screws, in their place, a 1/4" tap works to cut the threads, and make sure that the screws engage the shaft to prevent it from rotating. If it rotates, your supply can be completely cut off.ezernut9mm wrote:what is the purpose of those tubes? it seems like they just redirect a lot of the oil back to the pan. i would like to block them off and keep that oil up top.
Another thing people do is to pinch the tubes most of the way closed. This will force more of the oil to the rockers, while still providing oil to the timing gears and distributor gear.
Any way you do it, you're not going to keep more oil up top. It will flow to the back of the head, and back to the pan, which is really where it needs to end up because the rocker shafts are the end of the line.
