Started the interior restoration
F7BIGJOB wrote:drivers side,
passenger side
Alan, I will try to find a cigar lighter for your dash if you REALLY need one :P :laughing: [/quote]
Steve, I put them there so you could see how many extra holes the PO had put in the dash!, 29 I think was the count!
F7BIGJOB
Post by F7BIGJOB »
Steve, I put them there so you could see how many extra holes the PO had put in the dash!, 29 I think was the count![/quote]
:shock: OMG
F7BIGJOB
-Steve
1965 F-250 4x4 Flareside
f100jim
Post by f100jim »
Alan, what on earth did the PO have mounted in all those holes? :shock:
I don`t know!, it`s got me beat!
BigMike
Post by BigMike »
I was hoping to have had the interior stripped and sanded by now. It rained all weekend and I had to work on the Jeep. I rear ended a lady a couple of weeks ago <insert joke here>. It only messed up my front bumper and bent a small bar that protects the electronic swaybar disconnect. I spent last week installing an awesome new bumper and repaired the bent bar. You can see the bar under the bumper (before I straightened it). I have a 2nd piece to the new bumper that is a skid plate that mounts under there that still needs installed.
It rained all weekend and I want to work on it outside instead of being cooped up in the garage. I left the Slick outside Saturday night and it POURED down rain. I went out yesterday and opened the driver's door and now I see why I have a surface rust spot. Water just poured out of the interior and was pooled at that spot. Ordering new door seals today. :lol:
1991 Porsche 964 Cabriolet
2006 Cheby Silverado
HiBoy63
Ireland
Post by HiBoy63 »
Hey BigMike just be aware water pooled there may not be a door weather strip problem. May be from an ill fitting windshield gasket or from the front air intake cowl infront of the windshield.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
2001 Sport Track 4x4x4.0
Heritage country Flag
bird55
Post by bird55 »
Or simply where the WW posts go through the cab, like mine.
Jonas
Post by Jonas »
Alan Mclennan I have two 1966 trucks kick panels are the same on both sides. I have not seen a 65 or 66 that was different.
1997 F250HD 460 4X4
2004 RoadKing
1984 FLHS
1978FXE
HiBoy63
Ireland
Post by HiBoy63 »
Jonas wrote:Alan Mclennan I have two 1966 trucks kick panels are the same on both sides. I have not seen a 65 or 66 that was different.
I own a 65 F100 4x4 it has both style of vents in it. On the drivers side is an oblong shaped vent. On the passanger side is the typical 65-66 kind of triangle shaped vent that is a manual opening vent.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
you know that's funny!, the oblong one is on my drivers side and the triangle one is on the passengers side!, so it make you ask! what is standard for a 65/66?
BigMike
Post by BigMike »
Whatever they had laying around
HiBoy63
Ireland
Post by HiBoy63 »
:hm: Maybe it makes a difference in which assembly plant the truck was put together at. Possibly if it was a special order or standard cab or custom cab. My 65 is 4 wheel drive so the cab looks a little like my 63 that has 2 oblong vents with pull cables. So my 65 cab is like a blend of both those years as in maybe a retool so that triangle kick on the passanger side was the only one that was available at that plant. We probably will never know as I have read on the other web page that ford destroyed most of their records for 65. :hm:
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
65ford1
Post by 65ford1 »
Whats on top of your gas tank is more than my life saveings , great looking truck. Gene
BigMike
Post by BigMike »
I was wondering if anyone would have noticed that. It was under the seat. I was hoping to find a 1965 penny.
HiBoy63
Ireland
Post by HiBoy63 »
Hey BigMike looks like my 65 had the same seat upolstery design on the seat.
Mines a little more worse for wear than yours. The only thing I will save from this seat is the gear and lightning bolt that is embosed in the seat back.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
bird55 wrote:Or simply where the WW posts go through the cab, like mine.
There are drain holes into the cowl just under the wiper bezels. If you do not keep these clean you will have a wet floor when it rains or even washing the truck.
That's a good looking Jeep!
When you going to upgrade to an XJ?
BigMike
Post by BigMike »
HiBoy63 wrote:Hey BigMike looks like my 65 had the same seat upolstery design on the seat.
Wow, that was a hellva fart. :P
BigMike
Post by BigMike »
Another weekend goes by and no work done on the Slick.
I went out to the garage on Sunday to finish the tear down on the interior. Since I can't even open the passenger door with it parked normally in the garage, I pulled it in at an angle. I soon realized that if the heater assembly (and antifreeze) was removed, the pedals and steering column, I wouldn't be able to move the truck until I'm done. Well not easily.
I'm going to start on it the weekend we get back from AZ. I've already informed the wife that Stella will have sole possession of the garage for about a month.
But I am dropping the seat off to be reupholstered tomorrow. I'm going to tell them to take their time since I won't need it for a while. But I'll bet it will be ready by Friday anyway.
Mike,"take your time!", That's the single worst thing you can say to any repair place!, I told a motor shop that once!, and they took 18 months to rebuild a 8ba flathead!, They even said! it wont seem the same place without that on the bench! :roll:
BigMike
Post by BigMike »
Okay, I'm really going to start tomorrow.
I dropped the seat off at the upholster shop yesterday. They are doing an exact match on the turquoise vinyl. The seat will be a channel stick with a wide strip down the middle and sides. The "inside" channels will be a lighter aqua color. It should look pretty good. They asked me when I needed it and I told the 2 weeks would be fine.
Tomorrow morning I removing the heater, steering column, and pedals from the interior. Not sure if I'll paint of powder coat the pedals.
By Sunday night my plan is to have the inside stripped and sanded. If I get to primer, it will be a miracle. Supposed to be a gorgeous weekend and the Harley is calling out to be ridden.
When I remove the heater, I plan to have the heater valve shut, remove the hoses from the firewall and use a piece of pipe to clamp them together.
