LOL - so you're saying an FE that doesn't leak oil is an oxy-moron?fire truck wrote:Ah, well you mentioned the engine not leaking oil anymore, I figured that meant ditching the fe.... Hahaha!BigMike wrote:Same engine, 352.
It only has about 35k on the rebuild, runs like a top, and doesn't burn oil.
I'd love to drop one of these in there.
http://www.proformanceunlimited.com/spe ... P_AAL.html
BigMike's Front End/Engine Bay Clean-up Thread
1991 Porsche 964 Cabriolet
2006 Cheby Silverado
fire truck
I've been hunting a weird noise in the front end for a while. Knowing that the king pins were recently replaced when the disks were done, I didn't think it was that. While cleaning things up, I found the problem. The driver's side shock is loose at the top. I plan to replace the shocks anyway but makes me feel good that I found the source of the noise.
Long day in the garage today but we got the chassis and underside of the cab done with rust encapsulator. I didn't get done until it was dark so no pictures until tomorrow.
It's looking great.
It's looking great.
There is still a couple of hours before the bottom of the cab and frame under the cab is finished. My brother in law John has been a life saver. He did an incredible job cleaning the frame and under the cab while I was working on other stuff.
I've decided not to spray the chassis black over the rust encapsulator. This truck is a driver and I don't think I'll gain anything by using the paint.
Dont know if UV will affect your RE. I doubt may UV rays will get down there anyway. Looks good your making good time. Lots of work though isnt it?
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
2001 Sport Track 4x4x4.0
Heritage country Flag
1965 F100 4x4x352
1998 F150 4x4x4.6
You're right about the hard work.
I just ordered some parts from LMC. I need new steering column bearings before I put the power steering in.
I'll do a little bit of work this week and hit it again next weekend. Lots of parts to clean up and paint.
fire truck
I decided to top coat the Rust Encapsulator on the frame and underside of the cab. I used to be the parts manager at a John Deere and Bobcat dealer in Raleigh years ago. When I restored a '78 MGB, I used John Deere Blitz Black under the hood and in the wheel wells. That stuff wears like iron and after 5 years of daily driving, the paint in the wheel wells wasn't even chipped and under the hood looked just as good when I sprayed it.
I Googled Blitz Black and it seams that it is a hit with a lot of rat rodders. It is a low-gloss black. The other good thing about it is that it is cheap - $14/quart. I used rattle cans on the MG but will spray it with my gun on the truck. I Pretty sure I"m going to paint the firewall Caribbean Turquoise too. Should get all that done this weekend.
I got a package of goodies today from Summit Racing.
Chrome Valve Covers ($46, great deal)
Matching Breather/Oil Cap
Wire Looms
Now I just have to get my ass out in the garage and clean the engine, replace the gaskets and seals, sand it, and paint it. Sounds like at least 8 hours of work.
Wire Looms
Being between jobs right now, I have time to work on the Slick (hoping that will change next week as I'm a final candidate for a position).
I picked up the John Deere Blitz Black today. I was reading on a forum where people have the best results thinning it with Mineral Spirits. Valspar makes the paint and also found out it is the same paint as Valspar Tractor & Implement paint. I went by Tractor Supply Co on the way back from the JD dealer to get a couple rattle cans of the stuff (1/2 the price of JD) and some Valspar hardener.
Thankfully it will be about 60 degrees the next three days and no rain. This is my timeline. In between I have to find time to help my wife decorate for Christmas.
Thursday 12/1
Clean and paint
Bellhousing and inspection cover
PS parts
Engine mounts
Alternator brackets
Clutch linkage
Transmission cross-member
Transmission
Hood hinges
Friday 12/2
Paint frame and cab
Paint radiator
Start cleaning engine
Saturday 12/3
Install front shocks
Finish cleaning engine
Replace engine gaskets
Paint engine
Wire wheel headers and paint (John)
Sunday 12/4
Paint firewall
Next week 12/5-12/11
Clean front clip
Paint inner fenders and core support
Undercoat inside of fenders
Paint Steering column
Install steering gear
Install brake booster and master cylinder
Install brake lines
Install wiring harness
Install steering column
Mechanical
Rear trans seal
Grease front end
Change trans fluid
Install clutch and bellhousing
Install engine and transmission
Install front end
Connect all wiring
Fill with oil and coolant
Install hinges and hood brackets
Thursday 12/1
Clean and paint
PS parts
Engine mounts
Alternator brackets
Clutch linkage
Transmission
Hood hinges
Friday 12/2
Paint frame and cab
Paint radiator
Saturday 12/3
Paint engine
Sunday 12/4
Paint firewall
Clean front clip
Install brake lines
Mechanical
Rear trans seal
Grease front end
Change trans fluid
Install front end
Connect all wiring
More stuff coming from Summit Racing today. I'm going to use their braided wire protector on the harness which will make it look really good.
Also bought some new Accel yellow wires.
Also, I'm picking this stuff up from NAPA today.
P/S Gear Box - Remfd
Carburetor Mounting Gasket
Steering Coupler Kit
Driveshaft Bearing & Support
Spark Plug - Copper Core - OE Type
Seam Sealer, 11 oz
Hose - Radiator Upper
Alternator - Remfd - Premium, 55 Amp
Starter Solenoid Switch
Hose - Radiator Lower
P/S Pump w/ Reservoir - Remfd
Lots of work to do so I better get at it.
Seam Sealer, 11 oz
Thanks Matt.matt2491 wrote:Hey Big Mike,
I've sprayed the blitz black before. Its really good paint for what it is. Very durable and has a nice sheen. I would use the Valspar hardener if you can get it. 1:10 ratio does the trick.
The engine bay resto is looking killer!
Yes, I found the hardener. I've heard 8:1:1 for the ratio of paint:reducer:hardener. I've also heard 10:1:1.
The 8:1:1 came from a guy on some forum I found out there and he worked for Valspar. I don't think it will matter either way.
Here is the post
Blitz Black
Valspar Paint, Makers of John Deere Blitz Black
#1. If the existing paint is relatively good condition (ie. no peeling paint, no large amount of rust, etc) no primer is needed. Scuff sand the existing paint with extra fine grit sandpaper, wipe surface with a clean cloth and then apply John Deere Blitz Black.
#2. If primer is used due to bare metal or minor surface defects, we suggest the John Deere Buff Primer (available in aerosols, quarts and gallons). This is a very "user friendly" formulation that provides good sandability, excellent filling/sealing properties and enhanced corrosion resistance.
#3. A reducer is needed for optimum sprayability and appearance. We suggest the use of the John Deere thinner/reducer (available in quarts gallon and fives). It is formulated specifically for John Deere paints. The mix ratio is 8 parts John Deere paint : 1 part John Deere thinner.
#4. John Deere Blitz Black is an "air dry" formulation...but if you want the paint to dry faster and harder, John Deere has a hardener in their product line. It is available in pints. The mix ratio is 8-1-1. 8 parts John Deere paint (TY25669 or TY6416) to 1 part hardener (REN3001) to 1 part John Deere thinner (PT158).
Some more info...the exact same formulation is used in the aerosols as in the quarts/gallons. This helps with touch-ups and is critical in low gloss applications such as the Blitz Black.
If any more information is needed, please contact me. I would also be very willing to discuss any paint questions directly with Jade at Moto-Edge.
Regards,
Shawn Mahady
General Manager
Aftermarket Specialties
phone 612-375-7942
e-mail smahady@valspar.com
Another long day cleaning and painting parts.
I got all of the black pieces done today plus the bellhousing. After I was done with all of that, I started cleaning the transmission. It has crap baked on it that was a beotch to get off. I spent 2 hours on it but probably have a couple more before it can be painted. I actually got down to the original paint which is RED. IIRC, Michelle painted her transmission red for her Ranger leaving the top aluminum cover natural.
There are many more parts but they are hanging in different parts of the basement. The crossmember and engine perches are done it Rust Encapsulator and then I'm spraying them JD Blitz Black. The other parts are semi-gloss ceramic engine black. I used the ceramic engine "aluminum" color on the bellhousing.
EDIT - yep, she did paint it red.
I was at it again today. Got the frame and under the cab painted with John Deere Blitz Black. It was really tough determining coverage painting over the rust encapsulator.
Tomorrow I'm painting the firewall Caribbean Turquoise.
Before
After (can't tell much difference but you can in person). Got the power steering gear installed as well!
Before
- slickmainer
Same here. This project was a combination of that and to get rid of the oil leaks. Like always, I took a simple project and turned it into a major one.slickmainer wrote:sharp! I usually keep my hood down as shows because the bay isn't as nice as the outside! haha
