Very nice ride and cool signature. Nice Starsky & Hutch wheels!! Definatly a "Heavy Hauler" with those extra springs.
I agree with DV65CustomCab on the king pin inspection. One other quick trick that my work while doing that is if you do feel a little slop have a helper hold down on the brakes firmly and try it again. If the slop goes away it's in your bearing, if the slop stays it's in your kingpin (or a little of both). Never tried this on a slick but it seems to work good on heavy (air) drum brake vehicles.
Yep a Grant, I actually haven't had that problem with this one. I do think that with some creative engineering one could make a horn ring that would mount a Slick horn button to the new wheel. Been saving a spare horn button for just this purpose.
Like others have said, the rust you're seeing is typical. The good news is that patch panels and repro parts are readily available. For the most part, anyway.
How do things look under the floor mat? I'd suggest you also take a close look at the area where box meets cab. It's a typical trouble spot too. You'll see it if you take the fuel tank out. Unfortunately you won't find any aftermarket patch panels for that area, but it's nothing a bit of metal fab won't fix.
