Page 2 of 3
Re: new guy from MN (MORE PICTURES?)
Posted: August 11, 2013, 8:02 am
by douglloyd
Hi Denny!
Thanks for posting the rescue photos. Lots of info for the board here to work with.
I USED to be from MinneSNOWta, but moved to TN about 20 years ago. If the taxes don't send you packing, the snow just might. That and summer lasting three weeks or so...
Sure wish my family had held onto some of the old iron I used to fool around with. You have a real good project worth putting time and money into. Slicks are a LOT sturdier than what you can buy today. My 95 F-250 looks like it could have been assembled by third graders.
For your truck, I would keep the bed original and patch the steel floor. The rear fender wells look pretty good in your pictures. If you really want a wood bed, I believe the stepsides had wooden floors(?)
With a straight axle front, you will want to either hunt up a disk upgrade kit or plan on REALLY keeping up with the original single master pot and drum brakes. Others here can advise you better on this part.
Nothing wrong with that engine, just depends what you plan to have this truck do when you are finished. I'd say you have the 'reliability' thing NAILED with what you have. Very easy to work on and simple to troubleshoot.
Welcome aboard and thanks again for the photos. My wife no longer lets me hitch up my car hauler - too much stuff follows me home?
Doug in east TN (formerly Heron Lake/Marshall/Hutchinson/Richfield/Lake City)
Posted: August 11, 2013, 8:45 pm
by digler005
Welcome from Delaware. This forum will answer any question you may have, by the way I like that green.
Posted: August 11, 2013, 10:14 pm
by Malibusurfer
To a fellow new guy, welcome from Oregon!!!
Re: new guy from MN (MORE PICTURES!)
Posted: August 11, 2013, 10:33 pm
by dennyboy
Posted: August 12, 2013, 12:08 pm
by Jerry D
Welcome from Northern Illinois. Not sure where you're at in Mn, but maybe we can get another member to meet us at Back to the Fifties next year? That and/or maybe Slick Stock. Both great events.
Jerry D
Posted: August 12, 2013, 12:57 pm
by dennyboy
Yes we will have to do that im 8 miles north of the state fair grounds. I do car craft every year and now hopefully back to the fiftys
Posted: August 12, 2013, 6:34 pm
by ken_b
I could be interested in that. I'm in the NW metro.
Posted: August 12, 2013, 10:56 pm
by dennyboy
is carolina classics the only ones who make the cab mounts for my 64. if i read right it's 165 for the pair. are they cheaper anywere else?
Posted: August 12, 2013, 11:11 pm
by rickairmedic
Dennis Carpenter or
http://flashbackf100s.com/ Are the only 2 sources for sheetmetaal and rubber products for our trucks ( that is if you want it to fit and work like original )
. Tom from Flashback is a member here by the way .
Posted: August 13, 2013, 12:24 pm
by dennyboy
Thank you!
Posted: August 16, 2013, 7:55 am
by dennyboy
ok so I am trying to get her running. I rebuilt the carb and put in new points, wires, plugs, cap, rotor, fuel pump and a started. compression is a little low on two cylinders but should still be good enough to start to re seat the valves that are leaking a little. I can allmost get it running!!!
My problem is that I didn't pay attention to where my mixture screw and idle screw were before I took it apart because they were rusted in pretty bad.
My question is how do i figure out where to set these for initial start up? my timing seems right.
I all most forgot. it's a Holley 1904
Posted: August 16, 2013, 8:55 pm
by 62bigwindow
Welcome to the club and nice truck!The cab mount bolts through the floor are correct.I would recommend cab mounts and any other repair panels from Tom(Flashback F100's).I got a set from him and were real nice.Be prepaired to modify them a little to get the right fit.
Posted: August 16, 2013, 9:23 pm
by rickairmedic
Denny the internet is your freind
Heres the info on that Holley
http://forums.holley.com/entry.php?429- ... lley-Carbs
Posted: August 16, 2013, 10:44 pm
by skidoorulz
The relay is the horn relay. Set the mixture screws at 1.5 turns out to begin with and adjust from there when running for smooth idle. The numbers on the block is the part number for the block. I believe it is a 1963 date code.
Posted: August 16, 2013, 11:10 pm
by dennyboy
well I'm changing my thinking haha. I'm going to pull the motor and start a full rebuild. ive come to the conclusion that with how much and how far i want to drive this little beast i want to start fresh. I'm going to go through the tranny, rear end etc etc. It will also be alot easier to do the body work with the cab off, box off fenders of etc etc. This will take some time i am very sure should be alot of fun I love doing this stuff! I will need your guys's help with this haha!
were do you guys attach the chains on these motors?
More pictures!
going to need an exhasut manifold..... or headers!!!
I am also hoping this means what i think it means but my measuring equipment is at work.
Posted: August 17, 2013, 8:14 am
by skidoorulz
It means it is bored 40 thou over.
Posted: August 17, 2013, 8:21 am
by BarnieTrk
[/url]
I'd suggest staying with an exhaust manifold. You should be able to locate a non-cracked OEM manifold without too much effort. I'd check the replacement for straightness across the manifold-to-cylinder head flanges and severe pitting. You may want to get it re-faced, no biggie, then don't look back...use the saved $$ you would have spent on the headers for other stuff.
BarnieTrk
Posted: August 17, 2013, 9:25 am
by dennyboy
skidoorulz wrote:It means it is bored 40 thou over.
I'm hoping so
[/url]
BarnieTrk
thank you are the headers just not really worth it? i'm just wondering.
Posted: August 17, 2013, 2:47 pm
by 62bigwindow
I had a header on a 300 and had problems with the carb freezing up in the winter.I had never seen or heard of this happening before or after.I had to come up with a way to get heat to the carb to overcome it.I would stay with a manifold IMHO
Posted: August 17, 2013, 3:50 pm
by unibody madness
Patriot headers are cheaper than clifford headers. The clifford intake in the newer models have a provision to run the heater hoses through a plenum at the bottom. I believe ezer may have one for sale, I bought mine through ebay seatches over a period of time,and one from a fellow member. Search clifford on here to find out more. If you cant find one I might be talked into selling one of mine
