Page 2 of 2
Posted: August 27, 2007, 1:05 pm
by killercoating
The crown Vic set-up out here is $650 for everything between the wheels... a good price considering the little work it requires compared to other set-ups...
Posted: August 27, 2007, 4:51 pm
by Shiny
killercoating wrote:The crown Vic set-up out here is $650 for everything between the wheels... a good price considering the little work it requires compared to other set-ups...
So who has done a tech article on this?
-Shiny
Posted: August 28, 2007, 10:08 pm
by 61ford
bout the closest thing to a tech article is over at fte in this mans gallery ive got some pics in mine and a little explanation but nothing like a magazine tech write up or nothing.650 is prolly right if the rotors and everything is good i got mine for 350 but i gotta get rotors calipers
Posted: August 28, 2007, 10:17 pm
by shawns fords
Shiny I believe there was a member on slicks when it was MSN that did an Aerostar front clip, those have to be easy to find up there as well I would guess. mabye someone here knows where that article on the slicks MSN is, everytime I try to go to MSN I have connection problems so im never there, just a thought for another idea besides the normal
Posted: August 29, 2007, 12:28 am
by Johnny Canuck
You mean like this
[albumimg]50[/albumimg]
Aerostar clip?
I am not supposed to give my opinion.
Posted: August 29, 2007, 1:10 am
by Shiny
Johnny Canuck wrote:You mean like this
Aerostar clip?
hehehe,thats gotta be a first for you,what ya step on your tongue!
Thanx for the pic.
I think I'm gonna look at the torino clip,gotta friend who has one sitting at his place I can get cheap(beer)
-Shiny
Posted: August 29, 2007, 8:43 am
by 6166 Junkyard Dog
Before jumping into front suspension ask around and see how many miles being put on since some of these I have seen are trailer queens. I am not a Chevy fan but I ahve used the Camaro with the bigger sway bar, take off the smaller rotors off , put the big 12" GM Rotors on then it will be the same as the the Mark V rear end and this will give you plenty of stopping powers , also this set up is having the box out front so it makes it easier to to align your steering shaft unlike some that might need 2-3 joints to get it right
Posted: August 29, 2007, 8:45 am
oh this will give you 5 on 5 bolt pattern all the way around for different wheel options, I knew I forgot something else to add AND also the Mark V is a Ford 9" rera as well
mind go faster taht
I can type
Posted: August 29, 2007, 9:39 am
by Shiny
Thanx 61-66 JYD,
So you've put a camaro clip in a slick then?Thrack width was good and you got it down low enough to suit your fancy?
The 12" rotors are from the Impala/Caprices,we did this on our Torino clip in our IMCA mdified too.
And the front steer clips drive way better then a rear steer clip.Way better geometry too.
-Shiny
Posted: August 29, 2007, 10:38 am
we did on a 64, cab was off we measured straight down the sides and the x the measurements as well across then set you hidth however you want before you do the first spot weld then double check once spot welded, check off your cabmounts the measurement from the floor to see how the hidth is then can go from there to see how to lower it last one we did took it to the frame shop several years ago did not need any alignment but we had jigs to keep everything in alignment
Posted: August 29, 2007, 10:51 am
by Shiny
We just did one on a 59 Apache,we Z'd it quite a bit to get the truck down low.Worked out great.I did move it forward about an inch to get the wheel in the proper place in the fenderwell too.
I figured the track width would be bang on for a Slick too.
Got pics?
-Shiny
Posted: August 29, 2007, 6:20 pm
by Shiny
Has anyone clipped their Slick with a Torino?
I've looked around and can't find any Slicks with em.
Thanx,
-Shiny
