What's a dwell meter ?
mercuryv8
Re: What's a dwell meter ?
Post by mercuryv8 »
Toyz wrote:Only off by 50%!!
Crankshaft degrees
Kevin, it sounds as if you are describing valve overlap. And yes, camshaft duration is measured in degrees of crankshaft movement. Two easy ways to remember; degree wheels are normally installed on the crank pulley; and, 270+ degrees of CAMSHAFT rotation would make for one radical cam; with a BUNCH of overlap!
64 f100
Post by 64 f100 »
Duration at .050 always meant starting and end point of the duration spec. . Overlap is I believe, a different spec and depends on centerline of respective cams lobes 106,108, 110 etc. and duration . Dwell meters are a thing of the past as are points. Find those infrequently at garage sales for little to nothing. Found that I set my points by feeler gauge and do fairly well. If you set the dwell, then you have to reset the timing as dwell will affect timing.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
Rich, the importance of dwell measurement becomes more pronounced as parts become worn. There are many factors involved, but average dwell as found with a meter is often a way of coaxing just a little use out of a worn distributor as opposed to setting the point gap at a single point in the rotation. While most of us probably don't bother on our own vehicles, a timing check can be of value any time points, etc., are adjusted.
