Page 2 of 3
Posted: March 23, 2008, 12:01 pm
by banjopicker66
I bought a 98 F-150 XLT with about 80K on it, 4.6 V-8, automatic overdrive, PS, PB, A/C, and drove it hard. It now has nearly 200K on it, and it still runs quite well. I had the following problems:
Replace radiator (side tank leak)
Replace upper and lower ball joints - purchasing the tools was cheaper than paying the labor
Replaced the heater core twice - known issue from the factory
U-joints - all
Spark plugs and wires are a bear to change
Common problem is the EGR differential sensor and or the sensor tube go bad, and can be hard to fix. Often, removing the EGR bypass plate under the throttle body needs to be removed, and the carbon oily crud cleaned out of the passageway. 2 hour job and easy.
Those are the worst. Of course, regular trans flushes, oil changes, greasings, etc.
Stay away from the 4.2 V-6. They have known head issues that are expensive to fix, and the fix doesn't always work. The problem is in the heads warping.
Posted: March 23, 2008, 1:47 pm
by FORDBOYpete
Banjo,
Don't think I "lost it here" with this next comment.
Check draw in your cooling system between system ground & coolant with your VOM set for mV's.
Open cap & put probe into coolant, connect neg clip/probe to system or Batt Grnd.
If it reads more than .012 mV (if I recall correctly) then Ground your heater core to something that's a part in
your vehicle common ground circuit.
No it's not voodoo, it's electrolytic errosion 101, the core is isolated by the nonconductive heater case & plenum.
I'm looking for the actual text, think the society of corrosion engineers are the author. . . . got a slight case of CRS, ya know?.
I'll email ya.
FBp :thumright:
Posted: March 23, 2008, 3:19 pm
what about upgrading to a slick in better shape than the one you are currently driving?
at least you know all the things to look for that are important and can deal with the repairs if needed by yourself.
Posted: March 23, 2008, 3:43 pm
by banjopicker66
FBP - Electrolytic corrosion was the first thing I thought of - but it was not even measurable.
The original core went out in 2003, the replacement went out in 2005. The replacement went out two weeks later, so I guess it was replaced 3 times, the last one under warranty from the first.
The seams went bad, not from brass corrosion but the soldered seams let go.
Both of them went out in exactly the same place, and you could see where the solder was weak.
Posted: March 23, 2008, 3:55 pm
by FORDBOYpete
Roger That BP66, I copy you.
I sent you the ref' text anyhow And... I... err. . . :oops: :roll:
CIAO
FBp :steering:
Posted: March 25, 2008, 12:52 pm
by GLindley
banjopicker66 wrote:...Spark plugs and wires are a bear to change...
I'm assuming because of how part of the engine sits under the cab?
Posted: March 25, 2008, 7:50 pm
by greythorn3
new = expensive
Me=CHEAP
Ray
Posted: March 25, 2008, 8:42 pm
by ezernut9mm
that and the coil packs sit right on top of the plugs and they're down in the valley by the intake.
Posted: March 25, 2008, 10:37 pm
by shawns fords
no plug wires to change. coil packs on top arent hard with the correct tool, a 6 mm socket that fits the 1/4" drive ratchet, one bolt, then pull the boot and the plug, you need the right socket for the plug as well. I use a double wobble spark plug socket. ( not a universal joint adaptor) Never had any 4.2l troubles. I know of one I used to maintain regularly with over 200k on it in the first three years of use as a Drywallers trucks to get his crew to the jobs working over 9000 foot elevation all the time. Well maintained vehicles dont have troubles. Even well maintained Abused ones. My 78 and my 06 are perfect examples of that.
Posted: March 27, 2008, 7:38 pm
by GLindley
If a 2000 F-150 is supposed to have the "Tow package" how does one know if it actually does? Is there a place on the VIN tag for this?
Posted: March 27, 2008, 8:24 pm
by shawns fords
It will have a factory installed hitch with the wiring harness, and if the original owner or lug in harness with relay in a bag in the glove box, as well. the window sticker will say that. I dont know how you could identify it by the VIN. but I know the hitch Reciever and harness is there, and it will be factory installed. along without any funky U haul butt connectors or anything. Should have a nice little connector for your trailor wires to hook up to. some of them have a 7 plug RV and some just have a 4 blade for lamps. either way, you still need to buy the brake controller if you need one
Another way to look is the owners manual will show you the locations of the trailor relays locations and where everything related is located
Posted: March 28, 2008, 6:18 pm
by GLindley
What about a trans cooler? Does that come with a tow package, or is that standard with a 5.4/automatic?
Posted: March 29, 2008, 9:59 pm
by Lowell
My 02 with the towing package came with a transmission cooler.
Posted: March 29, 2008, 11:21 pm
by shawns fords
as far as I know it would have a external trans cooler with the tow package. I do not know how far back that runs for production. Probably in 97 since thats when the new bodys started coming out and Dealers didnt have to add on rear bumpers. or hitches. I do know my 06 with the 5.4l auto has both external trans cooler and engine oil cooler, which is part of tow package. my memory is a bit vague. I only remember 7.5l having external oil coolers in the heavier trucks 250 and up. I dont remember the light duty having any extrenal coolers before 97, but that doesnt mean they didnt
Posted: April 13, 2008, 9:30 am
by GLindley
It's a done deal...this is sitting in my driveway..
Posted: April 13, 2008, 9:52 am
by shawns fords
nice looking slick there :lol:
Posted: April 13, 2008, 12:09 pm
by GLindley
shawns fords wrote:nice looking slick there :lol:
Thanks. I guess it might mention it's a 2000 4X2 automatic, 5.4 Triton with 109K on it.
Posted: April 13, 2008, 1:26 pm
by 6166 Junkyard Dog
here we go on new Ford Trucks, I guess when you compare it to the other junks there ok but after the last few months with my super duty its a piece of junk, since last summer been pushing water , go to Ford pay money for all kind of tests, nothing found and when I mean pushing water we are talking about gallons. Now this past week we have put over 25 gallons of water for a 2600 mile trip 5 cans of stop leak and will go to Ford again to see whats the, heck on the side of the road in La. the other day gauge was buried, water coming out of the water tank as fast as you can put it in, wnet to the closest Ford Dealer told me tough come back Monday well that did not sit good so after 4 more cans of stop leak slowed it to about 6 more gallons to the house, the new 6.4's well somebody should have been shot over that hunk of junk, my son has one for a service truck good if you like to own your own service station with terrible fuel mileage and don't hit anyting with all those radiators in the front Sorry but Ford does not have it together since the 7.3 was taken away. my biggest fear is to have a wreck, ambulance come get me in a 6.0 and it dies also SORRY BUT AFTER Getting some mileage closer to 100,000 these trucks will not hold up. F-150's are ok for the average person
Posted: April 14, 2008, 12:25 pm
by adrianspeeder
'97-'98s have spark plug wires with two coil packs, '99+ have coil on plug (COP).
The '99-'02ish 5.4Ls have a known issue with spitting out spark plugs due to limited threads in the aluminum head, and improper torquing. Heads were redesigned, then the plugs, then now there is a TSB on how to handle the older 5.4Ls. I'll dig it up for ya.
All automatics got an external cooler.
Dad's '97 was great for the first 100k pullin, haulin, 4wheelin, ext, with the awesome 4.6L M5OD-R2 combo. Now we are tryin to figure out an overheating issue and my knowledge of the tritons ain't that of ford pushrods so it's kinda disappointing.
Adrianspeeder
Posted: April 14, 2008, 7:50 pm
by shawns fords
I dont knodiesel these days anyways. they never held up once the manufacturer put turbos on them then started changing shit. 100k was the best for anything before it started coming in hence the reason dealerships now have several technicians rather than one diesel guy. them 7.3ls were good when fuel was 80 cents a gallon not 4.00. so many people buy them and dont even NEED one. youll Enjoy that Truck Gene
