Page 2 of 2
Posted: May 17, 2008, 5:00 am
by blackagatha
personally I think I would drill a 1/8 hole on both sides of the bolt and zap the nuts in place with the MIG. I think it would be Minimal destruction of the paint... and likely hidden behind the hinges anyway.
Posted: May 19, 2008, 2:49 am
by Alan Mclennan
So Johnno, hows your nuts going, can you put your hand up from behind and touch them
, Cobber, let me know how its going
Alan,
Posted: May 19, 2008, 9:27 am
by Johnny Canuck
I tried six ways from Sunday to get those suckers off, but after a week of so of cussing and swearing with my hand up a vent, I ground the heads off the bolts and pushed the offending nuts thru. Now, I am making up some 3/16 plate , tapped, to take the bolts. I will rivet the plates to the firewall I'd snap some pics , but my dad took them to drill the holes 1/64 larger and tap them.
Just another huge time waster for a guy who is running out of time.
Posted: May 19, 2008, 10:08 pm
by FORDMANLCRACKEL
Johnny Canuck wrote:I tried six ways from Sunday to get those suckers off, but after a week of so of cussing and swearing with my hand up a vent, I ground the heads off the bolts and pushed the offending nuts thru. Now, I am making up some 3/16 plate , tapped, to take the bolts. I will rivet the plates to the firewall I'd snap some pics , but my dad took them to drill the holes 1/64 larger and tap them.
Does that mean you're going to drive it to SS?
Lonnie
Posted: May 19, 2008, 11:29 pm
by blackagatha
well, I'm beginning to believe I will not be able to meet you there... Im not seeing the cash thingy panning out. damn!
Posted: May 20, 2008, 8:04 am
by Johnny Canuck
Lonnie. Yes I plan to drive it there. If that crazy clock would give me a break.
JC
Posted: May 21, 2008, 2:19 am
by Alan Mclennan
Johnno, Calm down and just do what you have to do and it will all be alright! Hey! whats that TIC TIC TIC TIC I can hear, have you got a pace maker or something, there it is again TIC TIC TIC TIC . Did I tell you Lyn and I leave in 79 days, gee doesn't time fly. see you soon
Alan,
Posted: May 28, 2008, 8:10 am
by Johnny Canuck
OK, so in the end, the solution I came up with was to grind the heads off the bolts, and push them thru. Then I got some 3/16" strap iron, would have preferred 1/4". Tapped the holes in the strap iron on riveted them in place with pop rivets, to replace the old 'D' bolts..
here's the result.
Posted: May 28, 2008, 8:28 am
That looks like that worked great JC!
I'd post it in the "Hints" too in case someone has a similar problem.
Posted: May 30, 2008, 3:13 pm
by clevor347
Here's how you fix it..
Posted: May 30, 2008, 6:22 pm
by Slick Fan
clevor347 wrote:Here's how you fix it..
AWESOME!!
Is the front latch off the same garden gate?
Posted: May 30, 2008, 11:07 pm
by blackagatha
oh boy that's ugly! welded on even!!! wow
Posted: May 31, 2008, 12:40 am
Slick Fan wrote:clevor347 wrote:Here's how you fix it..
AWESOME!!
that is how my 66 4x4 was when i got it. no big deal, i bought it for the frame and put a good cab and bed on it.
still have the hood with extra holes in it somewhere, just had screws in the hinges.
the nice thing about those is you can swing the hood all the way back to rest on the cab, makes it a lot easier working on and seeing the engine.
Posted: May 31, 2008, 12:48 am
by blackagatha
yeah I am sure it must have been nice for being able to open the hood all the way back. Like Jeep CJs and wranglers... pure simplicity and they work well. it just looks kinda funny on a slick!
Posted: May 31, 2008, 11:29 am
by cookster4495
Posted: May 31, 2008, 12:28 pm
by Johnny Canuck
Get atter Larry
Posted: June 1, 2008, 1:29 pm
by wyatt
Glad to see you got it fixed J.C. Anyone working on these old trucks could have the same problem. I had the same problem a few years ago. You need to learn to recycle, my man
I cut the bolt off also. Then I hollowed the hole out with a small hammer. Then I took a body bolt (recycle) and set it in the hole with the threads pointing to the front of the truck. Then I welded the bolt in place. I put the hindge on and ran a nut and washer on it and said, There you go baby !!!!! Nobody has said anything about it yet.
Just remember, There is always a solution. Sometimes it takes awhile to figure out exactly what to do. See, now we have 2 solutions to that problem. Now get out there and finish that puppy!!!!!!!!!.
Wyatt
Posted: June 1, 2008, 3:36 pm
Actually something like that isn't ridiculous if you hid them underneath with 92-96 Ford truck hood springs.
Posted: June 1, 2008, 11:39 pm
by blackagatha
yeah, those big barn hinges would be tolerable if mounted under the hood...
and the idea of welding fender bolts to the hollowed holes... that is a very interesting idea... just, good luck trying to ever replace the bolts if they get stripped! Granted, the nuts are a royal PITA, but not so permanent.
