Stinkin' Lincoln 460 is finally done.
shawns fords
Post by shawns fords »
Yup thats how the speedo works, dont watch it too long while your driving, dont want to sign on one day reading a post about how you got mesmorized with old technology and crashed into a telephone pole or something ROFL
sounds like a Good Cam for that car, I bet the thing wil lgive you some good mid range power and great mileage on the highway
once the wife and kids feel how comfy the ride is they will enjoy it even more, plus feel much safer in it than about anything else on the road :D
this is the good side
uglyblue66
Post by uglyblue66 »
Once the family goes for a ride,the wife will love the safty and the kids will love the ride and room.And just think,the kids wont have to worry about Mom picking them up in a Minivan!How uncool! :shock:
Yep,I have got 14 to the gallon before.But that is useing cruise control on the interstate.Around town,heck no.And when I want to hear the mufflers, :twisted: It aint gettin much over 4 I am sure!
I also remember the time I stopped at the store and filled it up for .69,9 back in 84 to. :cry:
nice thing about the lincoln is the suspension. takes up most all the road bumps without you even feeling them. even rides the washboard dirt roads without vibrating the steering wheel out of your hands.
Slick Fan
Post by Slick Fan »
My kids are all grown, with cars of their own...so they already are past the easily impressed point, now I have to work harder to change their minds...and it doesn't always work. :lol:
I don't care, I still like it. 8)
ICEMAN6166 wrote:nice thing about the lincoln is the suspension. takes up most all the road bumps without you even feeling them. even rides the washboard dirt roads without vibrating the steering wheel out of your hands.
Yep, my Crown Vic was about the smoothest ride I'd been in for many years...this one will probably feel like I'm floating. :lol:
banjopicker66
Post by banjopicker66 »
Slick, If you plan on reselling it, use the zero timing set, don't over advance it from the original settings. The extra cam gear advance degrees (beyond zero) will for sure push you close if not over the emissions limit.
If you use the zero set and it still comes over the limit by a little bit, you can probably get the emissions back down if you retard the ignition timing a bit - and then set it back to your preferred advanced timing after you pass.
If you think you might keep it longer, (does Utah have sunset emissions laws for cars over certain age? Or Historic rating to make you emissions exempt?) put in a Cloyes 3-keyed set. You can set the cam timing at 4degrees retarded, up straight or 4 degrees advance.
Also make sure that the heads you rework are NOT D2V heads. Those are terrible for any performance, they have no quench area for detonation. If you use them, you will have to use premium gas and retard the ignition timing a bit (losing performance and mileage) or it will ping mercilessly. Not nice for a prospective buyer to hear who wants the gut-busting power of a 460.
Use D0V or D3V heads instead. D3V are the most common, up to 79 or a bit later. You can also use heads up to E6T, as they are almost identical to the D3V. Some E7T heads are carbed, and you can use those, but make sure they are carbed and not for a fuel injected setup. Those heads WON'T interchange.
Finally, don't exclude using a truck motor as a replacement. You can use any carbed 460 up to '87. You'll need to use the Lincoln sheet metal and other bolt-ons, but everything will bolt up fine to the heads and block.
VERY nice find, and good luck!
Slick Fan
Post by Slick Fan »
Thanks for the info, Banjo. :D
I was planning on using a Comp Cams 3-keyed roller set, but they are backordered at Summit...they have the Cloyes set, though & it's 5 bucks cheaper. Sweet, I'm going with that! :lol:
I'm planning on setting it at zero.
Utah does have a sunset emissions law, but '67 is the breakoff year...what a bunch of crap. It's been set at that year since they first enacted the emissions laws here in about 1982. :? Both these engines (the original Lincoln & the replacement engine) have D3 heads, so it sounds like I have a decent set to go with.
I won't be porting them now, but if I do end up keeping the car, I'll probably go through the engine again in a few years. I'll port the heads & put some flat tops in there...maybe a bigger cam & some dual exhaust, too. 8)
Well, the owner said it had chucked a rod (his words were "I blew it up"), and that was pretty much assumed when I looked at the rear of the oil pan. I could tell there had been some shrapnel inside that had dented the pan from inside, the engine's locked up, too. Today, I finally got a few hours to work on it & started unbolting stuff.
After a while, I went underneath to start unbuttoning the exhaust, removing the starter & removing the torque converter bolts, etc. When I removed the inspection cover, these two trophy pieces fell out...apparently, it did more than ding up the oil pan. :o
Then it hit me...if there's that much carnage inside there, I may not be able to coax the crank free so I can roll it over & get the t/c nuts off! :eek2: About two hours later, with the help of my redneck engineering, I was able to get it to turn far enough to barely get the last nut out. As I was turning it, 5 or 6 things fell & hit the pan from inside, and the rest of it sounds like absolute death. :lol:
Did I mention that I drained about 1.5 gallons of coolant out of the oil pan? I'm guessing it lost a head gasket, thereby filling the pan with antifreeze. Because oil floats, that means the oil pump was pumping straight antifreeze through the engine. That thing HAD to be making one hell of a racket before it went. :shock:
Here's the two chunks of engine block. I've decided that that's not "101"...it's really "LOL" :rotflmao:
I'll share the carnage pics once I get it out & get the pan off...'cause everybody like to see carnage, right? :P
shawns fords
LOL
the 460 that was in the bed of my slick when I brought him home was so froze up I just went down to Car quest and ordered a fresh reman. 72 Truck block, that engine screams bloody murder :lol: I think for 1500 bucks for a reman with a 5/50 warranty through a great rebuilder is well worth it. I have less than 2 grand into it with all the fluids. installation gaskets carb and intake, a bit more with everything else, but you already have all of that, Just a suggestion. I have a set of 68 C8VE heads I started a exhaust port on already then my machine builder talked me into a set of edelbrocks he already has ready to go which will work better for th purpose on that 429. so if your interested let me know shipping might be a bit high even to UTAH or I could haul them out to slick stock
blackagatha
Post by blackagatha »
haha absolute death...
I bet the water came from a cracked cylinder- throw a rod thru the cylinder, its going straight to the water jacket....
those chunks are thin! wow It always amazes me ho non-substantial most blocks are! I would think blocks would bust all over the place! haha
Slick Fan
Post by Slick Fan »
I haven't been able to work on it much in the last week, but today I had the from noon on to play...but first, a couple pics before I yank it...and who knows, I may have to look at these to refresh my memory on something. :roll:
After I removed the flywheel, I see that the couple small pieces of broken block are just that...the small ones! :shock:
The block is also broken above the oil pan. This area was hidden by the starter motor when it was still in the car, all I could see with the engine in the car was about 5 small-ish dents at the rear of the pan...only one had broken though a little bit & was seeping antifreeze.
Once I got it on the engine stand & dropped the pan, this is what greeted me...there's #4 rod & a chunk of crankshaft counterweight in that mess. *boom* :shock:
I didn't bother to remove those two oil pan bolts. :lol:
Both rear pistons are broken & jammed into the heads.
Looking down #4 hole...
And a crappy pic of #8 hole. The wrist pin is the shiny thing in the bottom there.
The cam retainer plate fell out in pieces, when I removed the timing cover. Oh & I'm thinking this may be where the coolant got into the block. The water pump & timing cover gaskets had a TON of silicone on them & the gaskets just looked like crap in general.
Apparently the cam had been shoved forward hard enough to break a couple lifters in their bores.
Four of the intake ports have piston shrapnel in them, this pic turned out best.
I had to stop there, hopefully tomorrow I can yank the heads. I'm now assuming the heads are garbage too. :( And, I was originally planning on just welding up the little divits in the oil pan...looks like I'm finding a new one.
I don't know about youz guyz, but this thing is one of the worst blown up engines I've seen in a LONG time. The friggin' thing looks like a dirty version of a top fuel grenade job. :lol:
This thing really had to have been making one hell of a death noise before it went. It's amazing the previous owner just kept driving! I can just picture a carload of old folks cruising along, when suddenly...BOOM!! :shock: :shock: :shock: :shock:
:shock: That thing is going to take some beating, or should I say has taken a beating! one thing in your favour is at least scrap metal is getting good money! :P
Alan,
BigTim
Post by BigTim »
Good call Alan, not much to reuse in those pics. Unless you need some weight to sink somthing in the lake. :shock:
Slick Fan did it the water pump look as though it had been chaged lately?
ezernut9mm
Sweden
Post by ezernut9mm »
wow! nice clean car. it's hard to believe that engine was tanked that bad.
jakdad
Post by jakdad »
Slick, if it were mine, I wouldn't invest time or effort on the heads. Bundle it all up for the scrap yard, go get another engine. Good luck, the old car is definately worth a new mill...........................
Jim
shawns fords
someone must have been really hauling lol
blackagatha
holy hell dude! hahaha
Slick Fan
Post by Slick Fan »
Thanks guys. Even though the engine is turning out to be a bit more than expected, I think the car still deserves to live again & will be fun to cruise in. :)
The pump is an Arrow reman unit that looks maybe 8 or 10 years old. Whoever did it, didn't take much pride in their work, either. There was a whole bunch of sloppily gooped-on blue silicone & from the condition of the gaskets, they didn't prep the surface very well.
I'll yank the heads today, but I'm betting the water pump area was the culprit.
jakdad wrote:Slick, if it were mine, I wouldn't invest time or effort on the heads. Bundle it all up for the scrap yard, go get another engine. Good luck, the old car is definately worth a new mill...........................
At this point, it looks like only the intake & exhaust manifolds, valve covers & timing cover are about the only reuseable things on this engine...oh & the distributor. :lol:
I got a $300 replacement engine a few days after I bought the Lincoln. The guy said it was from his Dad's van & that he was gonna put it in a Bronco, but gave up after a while.
The engine had a bunch of oil leaks, but it's innards looked pretty good. The block, crank & rods are at the machine shop now, getting spiffed up. :D
Here's a shot of that one...
I could tell it had been running lean in a few cylinders, I think I know why.
Does anyone need a 4x4 oil pan, motor mounts & oil filter adapter for a project? :D
jakdad
Post by jakdad »
Examine that distributor closely. no point in taking a chance on spark scatter on a fresh engine. Oh, for my personal use, I dont care for reman. dist. I prefer new, solves a lot of problems......................
Jim
Slick Fan
Post by Slick Fan »
jakdad wrote:Examine that distributor closely. no point in taking a chance on spark scatter on a fresh engine. Oh, for my personal use, I dont care for reman. dist. I prefer new, solves a lot of problems......................
Thanks, I'll do that. When I took out the one from the Lincoln, it looked pretty good & definitely spins freely. I'll double check for a buggered gear & bent shaft before I use it. :)
Anyhoo, today I yanked the heads...check out #4 piston. :lol:
#8 on the other side, was stuffed hard into the combustion chamber, but didn't break the top like the other one.
All but one cylinder had shapnel pieces in them.
Here's #8 rod, lookin' a little twisted in there.
To my surprise, the heads looked much better than I expected! Other than a couple intake valves that are hanging open a little, they look useable. #4 is on the upper left & #8 on the upper right.
I'm probably not going to use them though, mainly because I know the engine was low on coolant a lot & there's possibly some cracks in there. I'll have the heads on the replacement engine checked out first.
Here's the pistons, #4 rod, the crankshaft counterweight & a few chunks that came out with #4.
As for the reason of why the pan filled with coolant, I ruled out the head gaskets...they both look fine, so does the intake. However, the water pump looks like it was replaced 8 or 10 years ago & whoever did the job, didn't take much pride in his work. He used a ton of silicone & maybe didn't prep the area very well. I think the gaskets went on while the area was still wet with antifreeze.
Both gaskets came off really soggy.
I'm not gonna pull the crank & cam, There's nothing in there I can use & I already know they are fubar'd. You guys are probably tired of my Lincoln carnage pics, so I'll stop. I'll post a couple pics as I finish the new engine in a couple weeks.
Oh, one last one...there was one more broken lifter than I saw yesterday. The bottom halves are still in there.
Just something I find interesting, this is the first time I've seen lifters break this way. :)
blackagatha
eh I like the horrible pics.... if we dont wanna look, dont look it's that easy! haha
I am continually amazed by your pics.... and hope nothing like that ever happens to me...
BIGTRIP
Post by BIGTRIP »
it looks like abuse and neglect to me. stuff just doesnt "decide" to break like that, ya know? everything I have seen on the 385 engine tells how bulletproof they are until you hit a certain point of rpm or hp that stock parts wont be able to handle. even then for stock rotating they will handle alot more than most. I am just glad it was a fairly common engine and something that is easy to replace rather than something thats a little hard to come by. 300 isnt bad for a running replacement. I got mine for 500 talked down from 700. its good enough til i can build the one i want to build.
Being stroked is nice, but I would rather be blown!
