What have you done to your slick today??
- WrongBedDave
Re: What have you done to your slick today??
Built the driver side crank switch power window today. Gonna paint and install it tomorrow. Gonna type up the how to tonight so it'll be up in a few hours
Dave
63 Wrong Bed 2WD : 302/C4, drip rails shaved, aluminum radiator/e-fan, 16 gallon fuel cell, "custom" gauges, 1000W sound system
Photobucket Album:
http://s1084.photobucket.com/albums/j413/davewave649/
Build Thread:
viewtopic.php?f=32&t=27105
Photobucket Album:
Build Thread:
Put in a new battery in the '66 and went for a cruise for an hour or so. Spring is here.
Also split the 430/AT that goes in the '62 uni, got it on an engine stand and started stripping it down yesterday. Spent most of the day getting exhaust manifold bolts out, only broke 1 stud and 1 bolt. Got both out first try.
- Brians1966
Spring is finally here. My Son, Daughter and I
drove the Slick to the first Parkville Mo, Cruise Night of 2013. Loads of cars and trucks. But
was the only Slick at the Cruise.
to many chebbies though.
Going again first Sat of May. Maybe a few more Slicks will make it
1966 F-100 LONG BED, 240cid 3 speed red and white, Red and White Interior with a Mossy Oak Seat Cover
2013 Ford F150 STX Supercab 5.0 litre
DETERMINATION: The feeling you get right before you try to do something incredibly stupid!
CONFIDENCE: Is the feeling you have before you fully understand the situation!
Welded closed more holes in the drivers fender and worked some previous dents on the same fender.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
2001 Sport Track 4x4x4.0
Heritage country Flag
1965 F100 4x4x352
1998 F150 4x4x4.6
Last weekend I installed new chrome sun visor brackets and new sunvisors from LMC truck. Surprisingly good quality considering they are made in Tiawan.
Yesterday, I drove it to a local car show. Then I drove it on the freeway for the first time in 12 years. First time at sustained highway speeds since putting the truck back together. Discovered that my Ididit steering column had an emergency flasher switch on it, so that explains why my wiring guy didn't put my switch back in dash. Washed it so I could put my new LMC truck cover on it to hopefully keep the dust off and avoid some garage rash.
DanH
My son and his friend Colton helped me take off the front clip of our '64 F100 parts donor. Hopefully blueovalmadness still wants to buy the sheet metal now that it is off. He looked at it last october and said he wanted it, but I see he was trying to sell his '64 swb pickup earlier this winter. Now I remember why I waited so long to remove the clip, it was an afternoon job without the torch. I eventually want to shorten the '64 frame to reuse it as a place to store my '63 uni swb on until it goes to the bodyshop, in the mean time I can restore the original chassis. If Nick passes on the sheet metal, I'll be advertising it here first, then it goes with me to the swap meets. I am so happy that spring finally got here!
'31 Model A pickup, '55 F100 Yblock w/fordamatic, '56 F100 6cyl. 3 spd. BBW my first pickup bought when I was 13 in 1974, '77 Lincoln Town Car with 64,000 original miles For Sale
I put my hood on, ran the wiring to my new volts meter, installed speedo cable to the dash head, put all new ground straps on battery cables, Now I'm waiting for the motor to arrive on Saturday so I can complete the front end sheet metal 90% done after a year and half.
Doing some more welding and pounding as needed on the 65. 63 is taking a back seat for a month or two.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
Installed a front swaybar from a 73 F-350. What a great improvement! Makes the steering feel slower as I can go into turns much more confidently and not get thrown about.
Black 1985 GT
Yellow 1973 Mustang Mach 1
Black 2012 5.0 GT, 6-speed, Brembo brakes, 3.73's
Wimbledon White 1966 F-100 Shortbed, Styleside, 390, Tremec 3550, Fitech EFI
- bobenhotep
began the process of installing a new turn signal switch. I learned some stuff, and took a lot of pictures. I will post them when I am done.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"The Iron Rhino"
-duraspark II/ HEI
More welding side chrome strip holes on the passanger door closed. Welded up the holes that the previous factory rearview mirros left in the door and started to fill the hole in the bed side where someone had mounted what I presume to be a whip CB anntena. Pulled a dent in the front crown of the passanger side fender and welded in the slide hammer holes.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
- Brians1966
My son needed a subject for his police photography course so we rode down to English Landing In Parkville Mo and took some night shots of the 66.
Here are a few of the photos
- skidoorulz
Nothing! I worked on snowmobiles all day. Have to go riding again next weekend and want to be sure we are ready ahead of time.
- WrongBedDave
Fixed a squeaky fender (the skin had come loose from the rib that bolts to the cab) and put some finishing touches on the step i had replaced a while back. Hoping to get a lot more done while im home for the weekend
Dave
Photobucket Album:
Build Thread:
Photobucket Album:
Build Thread:
Hate to say it starting to sound like a broken record but more welding and more pounding and more grinding.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
longcabjohn
Bought a tailgate last friday, saw it on craiglist a couple of months ago priced way high waited to call price cut in half. Started sandblasting the inside of bed yesterday, need one more day about 5 hours, I work short days, then body filler and paint.
Johnny
Johnny
62bigwindow
Finished boxing frame,front shock mounts installed,front and rear suspension put back in and mustang tank mocked up.
Slinging filler into all the sunken welds and various dents all over the truck cab and bed. Im causing a bondo dust storm in my neighborhood.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
- F7BIGJOB
Oil, grease & filter, full tune up [points were thin] never even pulled the dizzy cap in the 7 or 8 years of owning, had a bit of a skip last weekend when I started her. Running excellant now, bought a new fuel pump for just in case and my carb kit should be in tomorrow. Started to mount the steps for the flareside finally, pics to follow when they are done.
F7BIGJOB
-Steve
1965 F-250 4x4 Flareside
-Steve
painted more of the frame, pulled out the seat and gas tank. Getting ready to get serious with the rust holes....
