Audio (part 2)
If your following my thread then last week you saw a glimpse of the console I built for the slick in another post, again this is built out of 3/4" scrap plywood and will be covered in vinyl when we do the headliner and door panels (future post), the area where the radio is mounted is made from a piece of acrylic (plastic) that is white and semi-translucent which will eventually be either covered in a vinyl graphic or hydro-dipped to apply a design to it.
The cup holders are aluminum and are sold by Summit they come in lots of different sizes and in natural aluminum or anodized colors.
The console needed to be tall and wide to fit the area under the dash and transmission tunnel, but short in depth from front to back so the seat could be moved in it's full range, my wife is 4'11" so for her to reach the pedals the seat needed to have full range of movement, we bounced the idea back and forth for several weeks about bench vs bucket seats and original seat vs something from the salvage yard, for now we just decided to use the original bench seat which will be covered in a future post when the seat cover comes in.
The face plate for the radio has switches and lights that I installed and will be used for various functions from activating the cruse control, over drive off, interior lighting, and other things.
The lights will give me some of the functions from the original CV instrument cluster like the check engine light, brake failure (low fluid) light, and other warning lights.
The radio has been sitting on the bench for over a month while I built the console and tested a few things, this is a double din radio with a 7" touch screen, it is also has AV functions, Bluetooth (pairs with my phone), a USB port so it can play MP3's from a memory stick or charge a phone, the USB also allows you to connect to you phone and display what your viewing on the phone on the radio screen, the advantage of this is you can use navigation software that is on your phone as a GPS that will display on the radio screen without using a stand-alone GPS unit. Of course has all the hands free phone stuff to call and answer the phone while driving if your phone is connected, even has a DVD player that can play movies (not while your driving I'd hope...lol) or a ton of MP3's off of DVD media.
But it has one other function that I wanted and that was provisions for adding cameras, and the truck will have two cameras both rear facing, one a standard backup camera which I have already installed and the other will be mounted high on the back of the cab in a hole someone previously had drilled to mount a bed light that I haven't installed just yet.
Both cameras were bought off Amazon and are cheap, because of the cost being low and the quality being really good now-a-days for these types of items it just made sense to have a back-up camera.
The back up camera I mounted in the pictures above can be used as a forward facing camera which is the mode it's operating in now, but using it as a backup camera it has two pigtails that you can cut to change or add functions which I haven't done yet, one will narrow the field of view the other will add guide lanes.
[edit] I forgot to add that the cameras all use standard RCA connections, they both came with 15' of cable that will also carry the power wire from the front to the rear, at the rear the connections to the camera is a RCA male and female connection and a standard 12v male and female connector, both of these connections are under the truck behind the roll pan, on both I use a large diameter piece of heat shrink tubing to seal or make the connections water tight, I also gave them a couple rounds of electrical tape as added insurance that water couldn't get to the connections in winter driving.
I also did not hook the camera to the backup lights to power it on, instead I powered it through a toggle switch at the moment, as dumb as it sounds I want to control when it is on and not rely on having to be in reverse to have a camera view out the back. The other camera when installed will be powered the same way which will let me chose which view I want (high or low), the radio will only display one feed at a time no split screen stuff...lol
[edit #2] In the last photo above you should notice a couple things, both are hard to see but right above the console under the dash is the OBD2 connector, above that you should be able to see the radio delete plate I made and painted to match the dash.
I don't have the console mounted to the floor yet, and will wait till it's covered in vinyl before mounting it for good, but it's kinda' heavy and fits to the hump pretty well it doesn't move around but will need to be secured when finished. I'll never use the phone functions other than the GPS, I don't talk on the phone while driving in fact see cell phones as mostly a necessary evil, I never carry mine around with me like most people and at home most people know to call my wife if they need to talk to me because calling my phone will be a waste of their time...lol
Jon
