Stinkin' Lincoln 460 is finally done.
Slick Fan
Post by Slick Fan »
BIGTRIP wrote:it looks like abuse and neglect to me. stuff just doesnt "decide" to break like that, ya know? everything I have seen on the 385 engine tells how bulletproof they are until you hit a certain point of rpm or hp that stock parts wont be able to handle. even then for stock rotating they will handle alot more than most.
Well, I can tell that the car has has fairly regular maintenance through the years. It's got a relatively new alternator, regulator, battery, ignition module, etc. All the lube points have been well greased...maybe a little TOO well. :roll: Regular cooling system flushes, oil changes, etc.
However, I can tell it's had an ongoing cooling system problem for the last little while. The water pump looks to be maybe 10 years old & whoever did the job, did it poorly. But, it's not that the owner neglected it, it's more like whoever was at the shop that the owner took the car to, was getting tired of seeing the same 'ol red Lincoln coming back time & again...and just kept putting band-aids on the problem. :? Maybe to keep the customer coming back, or maybe just because he/they didn't care about an old car. Who knows.
Here's my expert (or lack thereof) CSI deduction on the matter... :lol:
I can tell the radiator had been weak for a while, peeing coolant onto the radiator support. It brobably ran low on coolant fairly often in the past couple years, thereby further weakening the gaskets at the timing cover. When they finally replaced the bad radiator (with one made in China :evil: ), the timing cover gaskets at the water pump passages were weak enough by then to not be able to handle the newfound system pressure increase & promptly started filling the pan with coolant.
The owner complains that it's low on coolant & overheating again...the shop checks for leaks, seeing none, scratches his head, refills the tank & ships the car. 20-30 miles later, the engine can't take it's diet of straight antifreeze anymore & still pissed about having a Chinese radiator in it's system, decided to end it all...*BOOM* (four old folks in the car---> :shock: :shock: :shock: :shock: )
The shop picks up the car, takes one look at the oil pan, tries to turn the crank, tells the owner "it's blown up"...quickly followed by "it will cost $4,500 for a new engine & labor".
That's that, how'd I do? :mrgreen:
Oh & if the gasket was still good & the engine continued to run, the water pump bypass hose was poised & ready to be the very next thing to pop, guaranteed. :wink: :lol:
BIGTRIP
Post by BIGTRIP »
ouch. I have seen stuff like that and its usually been beat like a GOVT. mule right up til the failure. it sucks that a shop could get away with sabotage like that. i dunno if the shop intended to or not but if your diagnosis is accurate it would seem they are responsible.
Being stroked is nice, but I would rather be blown!
Slick Fan
Post by Slick Fan »
Yeah, i suppose so. Trying to prove it would be next to impossible, though. I guess that's why a lot of shops get a bad reputation.
BIGTRIP
Post by BIGTRIP »
word of mouth is a powerful tool. or weapon.
Slick Fan
Post by Slick Fan »
Well, I finally finished my engine...except I have an idling problem I haven't figured out yet. :hm:
I started a thread on a Lincoln forum when I was first looking at the car, a couple days before I bought it. That thread evolved into a "project" thread, so I'll link you guys there...less typing that way. :lol:
This is approxinately where I left off here on the Slick site--->LINKY<---
Here's a sneak peek at the engine all done. :D
Looks good!
shawns fords
Post by shawns fords »
you did a good job slick Fan, Truly professional work. LOL at the spark plugs and the Bolt in the intake story. :lol:
this is the good side
ezernut9mm
Sweden
Post by ezernut9mm »
nice write up s/f. hope you get your idle problem sorted out. with a maze of snakes like those cars have it's easy to over look something.
o/t, i totally forgot i was a member of that forum. lol i see some of the old members are still there.
BackyardRest
Post by BackyardRest »
NICE! had one same color but no sunroof.
If you have an idle issue could it be a vacuum leak? what kind of vacuum do you have at idle? does gauge fluctuate?
My Mark III is similar color. One of these days will get to it or just sell it as it sits sits sits....
Slick Fan
Post by Slick Fan »
Thanks, you guys. :D Yeah, I just about shot mud down both legs when I dropped that bolt in there. :shock: If I wasn't able to get it with a magnet, I would have probably pulled the engine again, flipped it upside down & kicked it until the bolt rolled out! LOL :lol:
BR, it sure acts like a vacuum leak. I put a gauge on it & it's fluctuating a lot. The more I think about it, I think the EGR valve may be stuck wide open. It looked clean when I had it apart, but with the amount of schrapnel that went through the old engine, it may have lodged a chunk inside there & I didn't see it.
I haven't been able to take it back off yet, to test my theory.
When I fired it initially, I had every vacuum port plugged off, even the distributor advance. So I know it's nothing on the car itself. Can't hear any sucking sounds, either.
That only really leaves the EGR valve & maybe an internal leak on the intake gasket...which would really piss me off. :x
Hey BR, show me a pic of your Mark-3. :D
