lincoln 460
Chris - your back, I thought you had given up getting an answer to your question. I however have it for you.
For what you want that, engine & tranny will move your 66 around. On the down side for you wanting it as a daily driver - you should be able to get a 5.0 and AOD combo for that kind of money and have the better fuel mileage.
BackyardRest
Post by BackyardRest »
Greg D wrote:Chris - your back, I thought you had given up getting an answer to your question. I however have it for you.
Not only that but its a BUNCH lighter than the 850lbs of a 460/trans combo. A roller cammed 5.0 can be built to make tons of power too if in future you want to add more. My 3800 lb ranger danger would get 26mpg with the SC 5.0. Probably heavier than your slick too.
It all depends on the HP level you are looking for.
ezernut9mm
Sweden
Post by ezernut9mm »
if i could find a running 5.0 and aod around here for four bones i would jump on it like it was my ol' lady.
