Getting back to it
HiBoy63
Ireland
Re: Getting back to it
Post by HiBoy63 »
just took a few after I pulled the radio back out. I used the outside mounting bracket to drill new holes to mount the radio.
Dash with the new mounting holes drilled. I went to mount the radio and found I had forgotten the center hole for the dial light.
DSCN5113 by HiBoy63-65, on Flickr
DSCN5115 by HiBoy63-65, on Flickr
Started to repair the roof line on the drivers side this will be my learning curve side. I can already see that when I do the passanger side I will make my cut about 1inch higher so that I can rust prohibit easier on the frame work and bracing for the roof.
It was mentioned that maybe the drip rails might have to be done away with. From looking at things with the rusted piece of roof removed Im thinking that I will be able to fix this rust without removing the rail. If they did have to come off it doesnt look like it would be that much of a job in the area of the doors at least. If someone was thinking of doing this for custom work it should be very do-able.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
2001 Sport Track 4x4x4.0
Heritage country Flag
HiBoy63
Ireland
Post by HiBoy63 »
I got the rusted roof piece cut out on the passanger side and por15d the inner frame of the roof that I could thru the holes left from cutting the rust out of the roof.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
