Falcon Ranchero
BackyardRest
Post by BackyardRest »
[quote="BigTim"]
BackyardRest
[quote="Blackwaterforge"]WOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Blackwaterforge
Post by Blackwaterforge »
Front end is a 73. I-Beams and Radius arms are forged (74 and up are stamped). Calipers are on front of rotors and are Dayton Dual caliper.
This front end carries the large king pins (1 1/16 I think). I think the GVW on the donor was 8100. The lighter trucks had smaller king pins and calipers. I did this exact swap on a 65 (drove it for 10 years then sold it). It is a direct bolt in. You will have to use the 65-66 springs or cut the 73's. You will have to swap in a dual chamber master cylinder and add a proportioning valve (get these from the donor). You can run into problems with missmatched brake parts. If they all come from the same truck you will have the correct proportioning , metering and residual pressure valves.
Hope this helps!
Jonas
Post by Jonas »
Blackwaterforge wrote:Front end is a 73. I-Beams and Radius arms are forged (74 and up are stamped). Calipers are on front of rotors and are Dayton Dual caliper.
Hope this helps!
I am doing the swap right now. 1971 F250 to a 1965 F250. Spindles are a direct bolt on. I like the Dayton Dual calipers. I'm just waiting on a few parts to finish it up.
My 65 is very close to the Blast from the Past Camper Special. Mine has three gas tanks also. When I had the truck painted I had newer gas lids put on. I did not like the orignal aftermarket ones. (Mine is not a CS)
I have the 352 (with headers and dual exhaust) I get about 12mpg. 410 rearend. The headers and exhaust really helped the way the truck ran and boosted 2mpg. Mine is Granny 4spd)
The tires are 30" tall. That helps I can cruise 70mph no problem.
1997 F250HD 460 4X4
2004 RoadKing
1984 FLHS
1978FXE
BackyardRest
[quote="Jonas"][
DCarr
Post by DCarr »
Thanks BR for the "requested" photos-yes I'm the guilty party. Hope you got a wheelbarrow full of cash for the duece-it's a fine piece. How did the injection work,what brain did it use? Again , thanks, David.
BackyardRest
[quote="DCarr"]
BR, that 427 S/C isn't a kit is it?
I like the 65 Cyclone in the backround too!
Did I see that Deuce in a magazine once?
BackyardRest
[quote="Greg D"]
Johnny Canuck
Post by Johnny Canuck »
BackyardResto wrote:
BigTim wrote:
BackyardResto wrote:Requested Cammer Pic
Drool......nice!
pic the one above started from and a couple more.
Hey that's impossible!
Garbz told me you can't put a big block in a deuce, only Chebbys will fit. I can't imagine Garbz BS ing me about a thing like that, that pic must be photoshopped :wink: :wink:
Absolutely gorgeous rod BTW, Gorgeous! :lol:
BackyardRest
Only iss
modeleh
Post by modeleh »
I was at the 75th Anniversary of the duece in Victoria, BC, 2007. There were over 400 '32 Fords there. The best car show I've ever been to bar none. There were many "A #1, first class" cars there including a B400 and pheaton, and every other bodystyle offered in '32. IMO, your car with that cammer would have been the best car there. Absolutely Outstanding! You are a lucky man.
1930 Model A Coupe and Roadster
1931 Model AA
1932 Model BB
1964 Falcon
1965 F250 CC CS
1966 F250 CC 4x4
1969 TBird
Greg D wrote:BR, that 427 S/C isn't a kit is it?
THE S/C is a contemporary. Very nice with a jag rear and all inc a real dual quad side oiler but if a person did not know they would have to look pretty hard to tell.
The Mercury is actually a R code Capri (1967) (8v SideOIler) 4spd 1 of 6 built.
If I remember right, the Contemporary is supposed to be closer to the original than alot of the others?
Do you have more pics of the Capri? I love to see them, I LOVE Comets. I had a 65 2 door post, was going to end up as a A/FX street car. That project got traded for a Grabber Blue 71 Torino GT though. 1 of 6, WOW. The grill really through me on it, I looked again and see the 66-67 body. I had a beater 67 289 comet too, had the pointed nose though like a Montego that year. The 65 style front clip I take it was on the Capri only. Were there no R codes of that car too? I don't think I have ever seen one.
BackyardRest
[quote="Greg D"]
Last edited by BackyardRest on October 10, 2011, 2:06 am, edited 2 times in total.
BackyardRest
Behin
BackyardRest
here i
BackyardRest
a bit
BackyardRest
Spoke
Slick Fan
Post by Slick Fan »
What if you used the '66 gate on the F250, since it's a drivable truck, then continued the search for another clean gate for the red truck? It's just my opinion here, but to me, Bumpside gates stick out like a sore thumb on a Slick.
Regardless, either choice would certainly look better than the big dent in the F250's current gate. :)
BackyardRest
[quote="Slick Fan"]
