Anybody know what this tool is?
Posted: April 13, 2009, 6:00 pm
The red knob on it ratchets.
It has Ford Motor Co. stamped into it.
Posted: April 13, 2009, 6:31 pm
by jakdad
Looks like a pilot shaft tool to align clutch discs. Keeps it in place while you install the clutch. That's close as I can get......................
Posted: April 13, 2009, 6:38 pm
by Gary Seymour
How big is that thing?
Posted: April 13, 2009, 6:40 pm
Bout 6" long, 3/4" diameter.
Posted: April 13, 2009, 6:45 pm
by 66 POJ
Look like it fits on a piece of square stock with the square inside, much like a gas key.
Posted: April 13, 2009, 7:00 pm
by MadMaxetc
Battery cable end reamer/cleaner?
Posted: April 13, 2009, 7:06 pm
The inside would fit a rod with 2 flats ground opposite each other.
Posted: April 13, 2009, 7:08 pm
by Gritsngumbo
jakdad wrote:Looks like a pilot shaft tool to align clutch discs. Keeps it in place while you install the clutch. That's close as I can get...................... :lol:
I agree!
Posted: April 13, 2009, 7:12 pm
It does sort of look like one. No pin on the end to slip into the pilot bearing, splines aren't deep enough, not big enough.
Posted: April 13, 2009, 7:27 pm
by Gritsngumbo
Maybe it's a henway?
Posted: April 13, 2009, 7:28 pm
by slick4x4
kinda looks like a knob that would be on a propane tank...
did ford ever build a bigger truck that ran on propane straight from the factory ?
thats my guess...
Posted: April 13, 2009, 9:00 pm
by Alan Mclennan
Going by the size!, I lean towards it being used to turn a double D shaft while a ring spanner that can slid down over it and do up a nut, like an Alternator shaft, if that's not it it must be something else!
Posted: April 13, 2009, 9:11 pm
by Kid
it is a ratcheting screw driver/nut driver tool. I had one just like it when I cleaned out my Dads tool box when he passed away, I have it somewhere around here and will look for it. It had screw bits and nut drivver type bits that went with it.................Kid
Posted: April 13, 2009, 10:56 pm
by f100matt
100%
Posted: April 14, 2009, 7:25 am
by fmartin_gila
That's what it is, I still have one. The little handle right below the red knob flips to rachet left or right.
Fred
Posted: April 14, 2009, 7:46 am
I posted this because my grnadfather used to have one when i was a kid - no bits, lol.
I honestly didn't know what it was either.
Been kind of fun, may have to hit the antique stores and see if I can find anything else to do this with, lol.
Posted: April 14, 2009, 10:50 am
by Phil
I cheated and asked here
http://www.460ford.com/forum/showthread.php?t=132862
I would say clutch alignment tool for a Ford Tractor, one set of splines for the motor clutch and one for the PTO clutch
Posted: April 14, 2009, 1:15 pm
by Lowell
Im guessing a special tool for automatic transmissions?
