Door Anti-Rattler and Vent Rubber Restoration
Posted: April 16, 2009, 5:43 pm
Just completed restoring both doors on my 66 F100.
The gents at http://www.Dennis-Carpenter.com published a 2 page how-to in their recent 57-66 catalog (2008 version with red Slick on the cover). though i found this helpful, and hope you will too, there are a few parts of the process i'd like to point out and amend.
Page 1 - property of Dennis Carpenter:
Suggested edit to Step 7: make sure your vent window is in the closed position after removing the footer screws in Step 6. There is a cam shaped 'stop' on the bottom pivot point of the vent window. If the window is closed, you should be able to extract the window without damaging paint and/or springing the sheet metal gap below the window. A closed vent window minimizes the cam's dimension for extraction.
Page 2 - property of Dennis Carpenter:
Suggested edit related to Steps 11 and 16: I suggest loosely attaching the vent window assembly (with it's rubber in place) during Step 11. Wait to pull the rubber cord until Step 17. If the division bar remains loosely attached, prior to installation of the vent assembly (Step 16) - you are liable to scratch paint with the tabs on the leading edge of the vent window frame. The twist and insert process for the vent assembly gets pretty tricky with the division bar in place.
You just went through all that trouble, no sense in scratching things up along the way. Good luck!
If you're working through this project, now would be a good time to get that Dynamat in your doors. What. A. Difference.
[/code]
[/code]
