need some help with my donor T-bird
Posted: June 3, 2009, 7:44 pm
by dotcentral
It is a 1991, 5.0 & AOD. My plan was unfasten all the connectors, drop the driveshaft, undo the trans and engine mounts, and pull the engine & trans as one unit. Seemed simple. :lol:
Any one have access to a diagram showing the various wiring connections, misc fasteners, etc that need to be removed to pull the engine and trans? I tried All-Data, and have struck out. Tomorrow I will try hitting up the local library for a haynes or chilton manual, but won't hold my breath they have one.
Seems like it should be simple, but is nothing at all like our trucks. I expected the driveshaft to be able to slip forward, then drop out after removing the U-joint retainers, but I am not sure the trans has enough play in the slip yoke to let that happen, unless the engine has to be jacked up or pulled to get the room needed. :hm: This car has the drive shaft passing through the gas tank, which might complicate things a bit, not sure.
I am also pretty sure I don't have all the wiring disconnected, but so much of it is between the engine & firewall, I can't really see much to tell. I thought I might start to pull the engine, and see what really needs to be disconnected.
Thanks for any help.
Maybe I am overlooking something basic here?
Posted: June 4, 2009, 3:42 pm
by The Big M
Different chassis, but when I pulled the 5.0/AOD out of my '87 Grand Marquis I just visually traced the wires and hoses to see what was attached. The key will be to disconnect the engine wiring harness at the firewall, where it connects to the computer. On the Marquis the computer was under the dash on the driver's side. The fuel injection wiring is fairly self-contained.
I just clipped the alternator harness, keeping the plug intact. Other than that, there was an engine ground, the starter cable, and a few vacuum connectors. There's also the throttle linkage, and the speedometer cable and TV cable on the transmission. That's about all I remember, other than the mounts and rad hoses, obviously.
As for the driveshaft, I disconnected it at the differential, dropped it, and pulled it out of the transmission. I had to keep the exhaust y-pipe intact, which created some difficulty. Unbolt the a/c compressor and power steering pump and hold them out of the way with some wire or a coat hanger. You may also need to remove the fan if space is tight (I expect it is).
Just don't force it and you'll be okay. If you encounter resistance just look it over and check for anything that may still be connected. Hope this helps. Good luck!
Posted: June 4, 2009, 4:38 pm
by ABA
Got this from a 1993 Service Repair CDRom. The same one the FORD Dealer repair shops use. Hope this helps.
Removal
1. Drain the engine cooling system.
2. Disconnect the battery ground cable.
3. Disconnect the wiring connector for the underhood lamp.
4. Remove the oil dipstick.
5. Mark the position of the hood hinges and remove the hood.
6. Discharge the A/C system as outlined in «Section 12-00».
7. Disconnect the A/C compressor lines. Cap or plug the open lines.
8. Disconnect the compressor clutch electrical connectors and power steering pressure switch.
9. Disconnect the generator wiring harness from the generator and position the harness out of the way.
10. Remove the fan shroud and fan assembly.
11. Remove the upper radiator hose.
12. Remove the air cleaner-to-throttle body tube assembly.
13. Disconnect the transmission oil cooler inlet and outlet tubes.
14. Disconnect the throttle and kickdown cables from the throttle body and remove the cable bracket retaining bolts. Position the cable and bracket assembly out of the way.
15. Disconnect the vacuum lines at:
l Upper intake manifold vacuum tee
l A/C control panel vacuum supply hose
l Secondary air injection valve
l EGR external pressure valve (vacuum and electrical connections)
16. Remove the upper intake manifold as outlined.
17. Disconnect the main engine wiring harness connectors at the dash panel (RH side).
18. Disconnect the heater hoses at the engine.
19. Position the engine wiring harness so it can be removed with the engine.
20. Disconnect the wiring harness from the coil and distributor and position the harness out of the way.
21. Relieve fuel system pressure as outlined in «Section 03-04C».
22. Disconnect the fuel inlet and return hoses from the fuel supply manifold. Cap the lines and fittings to prevent contamination.
23. Disconnect the lower radiator hose from the water pump.
24. Remove the radiator retaining bolts and remove the radiator.
25. Raise the vehicle on a hoist, drain the engine oil and remove the oil filter.
26. Remove the starter motor.
27. Disconnect the HO2S for the right and left catalytic converters.
28. Disconnect the battery ground cable from the LH side of the engine.
29. On the RH side of the engine, disconnect the brackets for the transmission cooler lines, engine-to-body ground straps and the starter motor wiring harness.
30. Remove the torque converter inspection cover and mark one of the converter studs to the flywheel for alignment during reassembly.
31. Remove the torque converter retaining nuts.
32. Remove the exhaust manifold heat shield at the left manifold flange and disconnect the exhaust pipe from the flange.
33. Disconnect the RH exhaust manifold flange.
34. Loosen the transmission mount retaining nut.
35. Remove the converter housing to engine bolts.
36. Remove the motor mount through bolts.
NOTE:
It may be helpful to drain the power steering fluid before removing the lines.
37. Lower the vehicle and disconnect the power steering lines. Cap the lines to prevent contamination.
38. Support the transmission with a suitable floor jack.
39. Install a suitable engine lifting sling on the engine lifting eyes. Lift the engine assembly clear of the engine mounts and remove the engine assembly from the vehicle.
40. Place the engine on a work stand.
Transmission
Tools Required:
l Bench Mounted Holding Fixture T57L-500-B
l Grommet Remover T84P-7341-A
NOTE:
If the transmission is being removed for a major overhaul, it is important to completely clean all transmission components, including converter, cooler, cooler lines, main control valve body, governor, all clutches and all check balls after any transmission servicing that generates contamination. These contaminants are a major cause for recurring transmission troubles and must be removed from the system before the transmission is put back into service.
The cleaning of debris from the direct clutch check ball is often omitted. This omission can lead to a repeat servicing of the transmission.
For cleaning and flushing procedures for transmission components, including the direct clutch check ball, refer to « Cleaning and Inspection» as outlined.
Removal
1. Raise vehicle on a hoist. Refer to «Section 00-02».
2. Place the drain pan under the transmission oil pan. Starting at the rear of the pan and working toward the front, loosen the retaining bolts and allow the fluid to drain. Finally remove all of the pan retaining bolts except two at the front, to allow the fluid to further drain. With fluid drained, install two bolts on the rear side of the pan to temporarily hold it in place.
3. Remove the converter drain plug access cover from the lower end of the converter housing.
4. Remove the converter-to-flywheel retaining nuts. Place a wrench on the crankshaft pulley retaining bolt to turn the converter to gain access to the nuts.
5. Place a drain pan under the converter. With the wrench on the crankshaft pulley retaining bolt, turn the converter to gain access to the converter drain plug and remove the plug. After the fluid has been drained, install the plug.
6. Remove catalytic converter assembly.
7. Remove body reinforcement.
8. Remove exhaust pipe and muffler assembly.
9. To maintain driveshaft balance, mark the rear driveshaft yoke and the companion flange so the driveshaft can be installed in its original position.
10. Remove four bolts retaining driveshaft to companion flange.
11. Loosen differential housing assembly rear mounting nuts approximately 6.4mm (0.25 inch).
12. Position axle stand under front of differential housing and remove forward mounting nuts and bushings. Pull vent tube from hole in subframe.
CAUTION:
Use care when positioning driveshaft so not to nick, burr or contaminate driveshaft yoke or companion flange.
13. Lower front of differential housing with axle stand and slide driveshaft out of transmission above axle housing. Let driveshaft rest on front driveshaft support and axle assembly.
14. Disconnect the cable from the terminal on the starter motor. Remove the three retaining bolts and remove the starter motor. Disconnect the neutral start switch wires at the plug connector.
15. Remove the rear mount-to-crossmember retaining bolts and the two crossmember-to-frame retaining bolts.
16. Remove the two engine rear support-to-extension housing retaining bolts.
17. Disconnect TV linkage rod or cable from transmission TV lever ball stud. Disconnect cable from bellcrank lever stud and remove self-tapping bolt from bell housing bracketry.
18. Carefully disconnect manual cable from transmission manual lever at transmission. Remove cable mounting bracket from case using Grommet Remover T84P-7341-A or equivalent. For tool usage instructions, refer to «Section 07-05».
19. Remove the two bolts retaining the bellcrank bracket to the converter housing.
NOTE:
Disconnect and remove any interfering exhaust system components.
20. Raise the transmission with a transmission jack to provide clearance to remove the crossmember. Remove the rear mount from the crossmember and remove the crossmember from the side supports.
21. Lower the transmission to gain access to the oil cooler lines.
22. Disconnect each oil line from the fittings on the transmission.
23. Disconnect the speedometer cable from the extension housing.
24. Remove the bolt that retains the transmission fluid filler tube to the cylinder block. Lift the filler tube and the dipstick from the transmission.
25. Secure the transmission to the jack with a chain.
26. Remove the converter housing-to-cylinder block retaining bolts.
27. Carefully move the transmission and converter assembly away from the engine and, at the same time, lower the jack to clear the underside of the vehicle.
28. Remove the converter and mount the transmission in Bench Mounted Holding Fixture T57L-500-B or equivalent.
Posted: June 4, 2009, 4:49 pm
by ABA
When I pulled that 3.8 out of mine I don't remember any thing out of the ordinary other than having to drop the gas tank to get the drive shaft out but the again I wasn't going to reuse it so it really didn't matter.
The trans is an AOD so it's not computer controlled like the AODE that FORD went to in '94 so all you got there are the coolant lines and the speedo cable.
Posted: June 5, 2009, 11:01 am
by dotcentral
Thanks for the list ABA. I'll print it out. I'm not reusing the driveshaft so I'll just cut it with a sawzall instead of messing with the tank.
Posted: June 5, 2009, 2:57 pm
by ABA
This motor and tranny going in your Slick?
How about the independent rear out of the T-bird? :shock:
Now that would be a fun conversion and would make for a nice ride.
Limited slip with a 3:73. :D
Yes I miss my street rod T-Bird. :(
[albumimg]2784[/albumimg]
[albumimg]1076[/albumimg]
Yes I still got those Cobra R rims and they are going on the Blue Bird pretty soon. :)
Posted: June 8, 2009, 11:10 am
by dotcentral
ABA wrote:How about the independent rear out of the T-bird? :shock:
II'd like to sell it. It is an idea, but then I'd need to get rid of the twin I-beam, etc. To be honest it has been almost a year since the truck moved under its own power. I want to get it back on the road.
My preference is to put the 5.0/AOD in my 71, and move the 351W into the slick. But I may put the 5.0 in the 66, just because it would be a bit more convenient to do so.
Posted: June 11, 2009, 9:00 am
by dotcentral
Well, getting there slowly. Took a sawzall and cut the driveshaft.
Someone over-torqued the starter bolts and one is starting to round off. Also having a problem with the engine mount nuts accessible from the top side. not enogh room to get a to much threaded bolt sticks up, so a regular socket wont fit, a medium or deepwell gets interference from the block, not enough room to get leverage with a wrench. I have the car on a lift, so I decided to try removing the towers instead. Driver side went easy, 1 one passenger side is in a bad spot. I think I will try to dig up my nut splitter and just cut those metric bastards off from the top.
Guess I need to order my engine harness soon. Wolffe and PFM-64F100 have good things to say about the RJM product.
