How to: Wire fuel level guage to tank sending unit
Posted: June 8, 2009, 5:30 pm
by BarnieTrk
Fellas,
In my '65 F250, I've got the standard round instrument cluster. The original behind-the-seat fuel tank was gone. I've installed a similar '68 fuel tank behind the seat. I've got it plumbed in and have been driving the truck -- no leaks. Now it's time to get the guage-to-sending circuit wired up.
1) First off, will the '68 sending unit be compatible with the '65 standard fuel level guage or do I need to change something?
2) Does anyone have a simple wiring diagram for the fuel guage circuit?
3) Is there a simple test to perform at the sending unit terminals to determine if it's good or not?
4) What about for the guage - is there a test for it as well?
Thanks in advance for any & all advice/help, Guys!
BarnieTrk
Re: How to: Wire fuel level guage to tank sending unit
Posted: June 9, 2009, 11:14 am
by jwh f-100
BarnieTrk wrote:Fellas,
should be ok
Check here http://www.tocmp.com/tOCMP/wiring/1964F100/
I wouldn't fight with it right now, give it a try before removing.
There is two wires going to the guage. The positive wire that goes through the little regulator. Make sure there is 12v to the regulator and 5 volts from the regulator to the guage. If all is good on the power side just ground the neg side and the guage should go to full..
BarnieTrk
Before testing all this stuff maybe you are all set. See if the wire is hanging down from the pillar behind the drivers door.
If more work is needed this photo may be helpful.. Ignore the wire colors as I just used what I had when I rewired my truck.. At the top right is the rear of the fuel guage. You will also see the regulator at the bottom behind the wires. I have a green wire as the 12v supply to the reg, then you will see a small "wish bone" harness with one going to the guage. The other red wire on the guage is the ground that goes to the sender.
Posted: June 9, 2009, 1:08 pm
by Hawkrod
Ford gauges are the same from the 30's to at least the early 80's so you are good to go with a 68 sender and 65 guage. Be sure the sender is grounded properly and like jwh f-100 said, just look for the stock wire and plug it in. To test the guage, ground the wire that hooks to the sender, guage should go to full. To test sender you either need it out or you hook it up and add gas and watch the guage. Hawkrod
Posted: June 9, 2009, 7:17 pm
by pcbdavis
I'm having issues as well, The Orange wire goes from the sending unit to the gauge, not ground. You ground from one bolt to the body. If I touch my orange wire with the light tester the gauge goes to fuel..... I'm confused now????
Posted: June 9, 2009, 7:24 pm
by Hawkrod
pcbdavis wrote:I'm having issues as well, The Orange wire goes from the sending unit to the gauge, not ground. You ground from one bolt to the body. If I touch my orange wire with the light tester the gauge goes to fuel..... I'm confused now????
Ground the orange wire and the guage should go to full. It did with the testor because ground traveled through the tester. I am not sure what you are talking about when you say "The Orange wire goes from the sending unit to the gauge, not ground" because I reread all the posts and it does not say to hook it to ground anywhere except where I said to test the gauge. As I mentioned, be sure to put a good ground on the sender. Unfortunately these senders do not get a good connection through the mounting hardware due to age and corrosion. Some senders actually have a tab on them for a ground connection but you can use one of the mounting screws and a star washer and run the wire to the body and be sure to use a star connector there too. Hawkrod
Posted: June 9, 2009, 7:36 pm
by pcbdavis
I looked at the picture F-100 supplied, the orange is connecting to the gauge but looks to be spliced to the red wire. F-100 said red wire on the gauge is the ground that goes to the sender.
Going to try a new ground place,
Thanks for the corrections.
[/quote]
Posted: June 9, 2009, 9:14 pm
by BarnieTrk
WOW! THANKS FOR ALL THE INPUT, FELLAS!!
Now I just need to read it about ten more times....
What gauge wire should those leads be?
Sounds like the circuit needs to carry 5-volts, so 14 ga. copper auto wire should be able to carry the load, correct?
Thanks again for everyone's input!
BarnieTrk
Posted: June 10, 2009, 12:54 am
by Hawkrod
pcbdavis wrote:I have a green wire as the 12v supply to the reg, then you will see a small "wish bone" harness with one going to the guage. The other red wire on the guage is the ground that goes to the sender.
[/quote]Always keep in mind that these gauges work by variable resitance in the ground lead, that is to say the orange wire is actually the ground wire for the gauge and power comes from the CVR/IVR on the cluster. All Ford did was make a rheostat on the ground to make the gauge go up and down. In this case the rheostat is the contacts on the pickup in the tank. Hawkrod
