Pulling a fully dressed 5.0 EFI
Posted: June 16, 2009, 9:34 pm
by dotcentral
Okay, after busting 2 craftsman nut splitters, and countless hours with a hand grinder I thinik I finally have the 5.0 ready for extraction form the donor Tbird.
Questions.
1. my engine chain is a bit short. I currently have it running to head bolts at opposite sides/corners, left front, right rear. I had to fish it under the efi intake, and it looks like this way will dent the valve covers. I figure I can buy a differnt pair cheap/easy enough, but do I have to worry about damaging the intake?
2. AC lines. I have already evacuated the system. Will the standard ac/fuel tool work to disconnect these, or does the ford ac lines have a special, non universal tool for undoing the lines?
Posted: June 16, 2009, 10:18 pm
by 36truck
1 get a longer chain or take the intake off.
2 The fittings are a standard size. 2 different sizes if memory serves me right.
Posted: June 17, 2009, 10:12 am
by dotcentral
Thanks.
I have a longer chain somewhere, if I can just find it.
Posted: June 17, 2009, 12:10 pm
by The Big M
Are there lifting lugs attached to the exhaust manifolds? My Marquis had them.
Posted: June 17, 2009, 2:05 pm
by dotcentral
I had to pull the exhaust to get access to the engine mounts, but didn't see any.
I will look again for lifting lugs, seems like there should be some somewhere.
Okay, intake question.
Posted: June 17, 2009, 6:44 pm
by dotcentral
Again, this is a 91 5.0.
I think if I seperate the upper intake plenum from the lower, I will have more room and be less likely to damage something. Is it just four bolts holding the two halves together? I have all the electrical connections unplugged, and I have bled off the fuel pressure.
I only see four bolts, but don't want to break anything trying to force it.
I posted this on another message board, and was told that under the little "5.0" tag there are two more bolts. I always wondered why there was torque bit screws on those. Guess I get to try again tomorrow.
Posted: June 24, 2009, 10:24 pm
by dotcentral
I finally got the engine & trans pulled. What a pain in the ass. I sure am glad I don't have to re-install this back into the T-bird.
Posted: June 25, 2009, 8:46 am
by Phil
dotcentral wrote:I finally got the engine & trans pulled. What a pain in the ass. I sure am glad I don't have to re-install this back into the T-bird.
I just pulled my N/A 2.3 /auto from my 93 stang
man that was horrible.
Now I find that there are no similarities beyond visual between 2.3 N/A and 2.3 Turbo engines. I may as well be swapping in a piano
Posted: June 25, 2009, 11:54 am
by The Big M
Well here's hoping it's an upright piano. At least with those you can recess the firewall and use a cowl induction hood for vertical clearance. A baby grand won't clear the shock towers.
