If you own a welder you should read this!!
Posted: July 30, 2009, 12:13 pm
by Shiny
Buddy Marshall from Washington just posted this on another board I'm on...
Even if you hang out at friends shops who are welding read this!
http://www.brewracingframes.com/id75.htm
-Shiny
Posted: July 30, 2009, 1:29 pm
by Max
I learned to take the time to properly clean any metal about to be welded and remove any solvents, paints, primers, residue, etc.
Taking TIG classes right now and they stress, stress, stress that - especially since TIG process heats the metal so much.
Posted: July 30, 2009, 1:44 pm
by willy3486
I second that. I actually got drunk one time off fumes from trichloretheline or whatever its called they put in cleaner. I worked at a factory in mantenence about 20 years ago. I was told by my boss no less to go into the cleaning room because they had a leak in the cleaning tank. Me and this other guy did as we were told and took the ladder lift in there. I went up the ladder and as soon as I got to the top about 10 feet off the ground I was getting high and came down. By the time I was down and out the door about 15 feet away I could barely stand. Then I saw some other guys from maintainence go in there with breathing masks like firemen wear. I got luck other than the spacey feeling for a few minutes I had no lasting effects. I liked the boss but he was bad for telling you to do things that wound up wrong. So be carefull out there.
Posted: July 30, 2009, 2:15 pm
you have to watch out for all sorts of reactions from chemicals, welding gasses and the fumes from tha actual welding.
brake cleaner is one of the nastiest chemical concoctions, i have known that for a long time.
was just recently helping my friend do a welding job with galvanized steel, you dont want to breathe very much of that either.
Posted: July 30, 2009, 4:08 pm
by 66fordtrucknut
It's a wonder I'm not dead. All the chemicals and degreasers, argon I've inhaled welding over the last 30 yrs.
Charlie
Posted: August 1, 2009, 3:30 am
by oldtrucks
Shiny
Thank you very much for the article I am going to print it and keep it in a place that I can see it often.
we tend to get lazy on safety in our home shops because we are doing "small" jobs and get lax on reading labels.
So thanks again and I am going to make an effort to become as safety consious as I was before I retired from Boeing.
motor mount
Posted: August 12, 2009, 9:57 pm
by motormount1
and when i worked in a chemical plant the piipe fitters could not weld on used pipe.
Thanks for that post
Posted: August 15, 2009, 5:28 pm
by HEITZ
I always clean the area with a solvent first..... normally I use a can of ether as it evaporates almost instantly and only costs a few bucks per can compared to other solvents. You only want to do this out side where there is no source of ignition. It works great.
I have several cans of brake cleaner in the garage and will make darn sure that situation does not happen to me.
Thanks for the POST.
Posted: August 17, 2009, 1:10 am
by Hoofbeat Racer
ICEMAN6166 wrote:you have to watch out for all sorts of reactions from chemicals, welding gasses and the fumes from tha actual welding.
Yes Brian, I am pretty sure phosgene gas is emitted from welding galvanized. Sure welds nice but be careful. Seems to me the term "zinc chills" comes from that.
Good post btw
Posted: August 19, 2009, 10:06 am
by 64 f100
I worked in a plant near me that had a lot of phosgene gas. At one time it was estimated that should the plant be blown up, it would kill everything 500 miles down wind of the plant. I thank you for the information you have posted, this is a need to know situation for all of us, and a good reminder of what can hapopen. I'm 62 now, and have many problems associated with welding, some may have come from that very same phosgene plant I mention. However, I have no proof that this has caused my problems this other welder has experienced. Over the years , I've had my hands in all kinds of cemicals, many considered safe for years, but not neccesarily so. I am still not as carefull as I should be, and coming to the end of my life, most likely won't change some of my habits. I won't live forever nor do I desire to do so, but it would be nice to not hurt any more than I do now.
Thank you for bringing this to our attention,
