Pulling a car trailer with a slick
Posted: August 1, 2009, 11:31 pm
by Evil86saleen
A few questions for the experts.
I am currently looking for a slick to use for part time daily driving and pulling a 14 foot car trailer with a 2400lb car.
I am looking at a 64 lwb sunday afternoon with the 292 under the hood.
My concerns are.
1. brakes
2. cooling system
3. tongue weight
4. the old Y block handling the load at elevations ranging from 6k feet to 9k feet with 7% grades.
Also. Anything special to look at when checking out the 64 beyond the usual old car inspection.
Oh and here is a pic of the car.
Posted: August 2, 2009, 6:33 am
by STOFFER
get a 2 barrel to 4 barrel adapter plate, run a edelbork 390cfm 4 barrel, long tube headers and a 2.5 inch dual exhaust with a crossover and you'll be fine...
I've towed many trailers with my '64 F-250, remember the rear axle is narrower than the front wheels, I rebuilt my brakes
the truck isn't a turbo diesel but it will still do the job
Posted: August 2, 2009, 6:42 am
by 64 f100
Two concerns perhaps three. The truck will pull it, if you have the original rearend. These trucks were built for truck use not speed. Brakes are of a major concern, hopefully you have trailer brakes. Don't depend on truck brakes too heavily in emergency situations. Stay out of emergency braking if possible. For one, you will glaze the brake shoes, and straight axles tend to pull left or right at times when braking . Keep speed down below 60 is my recommendation.
Posted: August 2, 2009, 6:44 am
by DV65CustomCab
Rallycross. We don't have that here, which is probably a good thing for my car budget.
You're trying to do something similar to what I'm doing with my truck (and sort of the reason I bought it so many years ago). I have not driven a pre-65, but can give some impressions based on owning a 65-66 style truck (Twin I Beam, FE V-8).
To me, disc brakes are a must, particularly where you live with the kind of hills you may need to deal with. Not only for stopping effectiveness, but to manage heat which drums do not do very well. The Twin I trucks are easily swapped to discs with factory parts; the early trucks require purchase of at least some sort of minimal 'kit' which will be spendy.
My FE is rated at 208 hp according to the air cleaner decal and it's adequate but not inspiring for power. I think the Y block will struggle. You may actually be better off with a six swapped to a 300. While I could probably tolerate a Y block here, in CO it's going to be a struggle with the altitude I'm guessing. The FE cooling system (with new stock radiator) does just fine. Can't comment on the Y's cooling abilitites.
The truck handles the weight just fine provided you place the car on the trailer properly. Trailer brakes are a MUST. Power steering sure would make parking a lot easier but I don't like the numb feel it gives (the racer in me) so I struggle with Armstrong steering, which really only sucks when backing it into my driveway at home.
These trucks were used for work when new, so are perfectly capable of handling such a task. The only problem is what we expect from them on a modern level. Newer trucks have superior steering, brakes, suspension, power, etc which makes life more pleasant. But, I'll put up with some of the shortcomings and take extra time for my trips to enjoy the coolness that is an old truck.
If I were you, I would go for a 65-66 truck which would enable the easier brake swap. As an added bonus, the cab is even larger. An F250 will get you heavier everything (brakes, suspension) but will have a non-fuel-friendly rear axle with a low top speed. The 4 speed is the way to go for towing, IMO, as you get the granny 1st gear and don't have the balky column shifter to worry about.
Posted: August 2, 2009, 7:13 am
by 6166 Junkyard Dog
I look for a 65-66 F-250 as well, change front over to Disc, then one great thing is that the rears will interchange from 53-72 and a lot of 68-72 will have ratios from 3:54 to 3:73 to 4:10 to getaway from the gears under a stock rear also could add powewr steering easier ++++ a lot of 250's are more reasonable price but look at body closely so your not getting a rust bucket or a lot of mechanical issues,,, trailers brake a must as well
Posted: August 2, 2009, 10:04 am
by frank66
#1 Brakes. I really wish I went with disc brakes instead of rebuilding my drums. Make sure your trailer has brakes and get a good brake controller for the truck. Mount the controller somewhere you can easily use the manual thumb slider switch, I use it very often.
#2 Cooling. My truck has never gone over 210 while towing. (no hills where I live) I have the stock 6 cyl radiator, a flex fan with out a shroud, and I usually run a bottle of "water wetter" in the coolant.
#3 Tongue Weight. I use a weight distributing hitch on my F-250. Try moving the car around on the trailer untill you find what works best for you. Just a few inches foward or back can make a big difference.
#4 Y-Block. Sorry, Don't know anything about them.
Posted: August 2, 2009, 10:25 am
I think I'd go with Junkyards suggestion, 65-66 250 because of the easy upgrades to the brakes. An F 100 would probably tow a light enough trailer with a small car like that pretty well but if you are going to use it alot abit of overkill wouldn't hurt.
You can always buy the 64 too and have some fum with it.
Posted: August 2, 2009, 10:28 am
by Johnny Canuck
IN addition to the guys above here, who really know what they are yapping about, be aware that an F250 rear end is a Dana60 not a ford 9" and you don't just swap the gears out in one afternoon on them.
A 292 with a 4 bbl would handle what you need to do with gears, I would be looking seriously at swapping in a New Venture 4500 5 spd out of a modern Dodge diesel tho. Those are one sweet tranny.
Posted: August 2, 2009, 11:43 am
by Evil86saleen
Thanks for the info guys.
I would use the Dodge for any long hauls and pulling the 28 foot enclosed trailer.
Now I have a few ideas and time to do some research on the upgardes every one mentioned.
Looking at this one today. Bringing my jump box and some fuel/oil with me.
http://denver.craigslist.org/cto/1272157519.html
kyle
Posted: August 2, 2009, 11:45 am
by jakdad
I think more than anything, common sense is all that's needed. your 292 if in good condition should be fine. You would be the best judge of what to do with the brakes. I would caution you to never load the car on the trailer backwards. Not enough tongue weight. Good luck.
Posted: August 2, 2009, 11:50 am
by Johnny Canuck
Price is right. Hope the engine is free... at least he didn't write "Ran when parked" LOL
look for rust in the usual spots, front cab mounts, floor boards under pedals/above cab mounts, cab rear corners, drip rail, behind the front wheels at back of fenders and door jamb/ step there too. and the front crease of the hood.
Posted: August 2, 2009, 12:01 pm
by Evil86saleen
If the 64 doesnt work out maybe i will look at this one next week.
http://denver.craigslist.org/bar/1290870652.html
kyle
Posted: August 2, 2009, 12:05 pm
by Evil86saleen
Johnny Canuck wrote:Price is right. Hope the engine is free... at least he didn't write "Ran when parked" LOL
I talked to them yesterday and the sellers dont seem to know much about the truck. Sounds like it was the daughters husbands truck. Supposedly he started the sucker every month and moved it around.
kyle
Posted: August 2, 2009, 12:08 pm
Both look like decent trucks for the money.
In my opinion though - the 250 is $800 more money, you would likely spend more than the price difference getting the 64 to the same level. You'd be $ ahead in the long run with the 250 and it would be better for towing and cheaper to upgrade the brakes, etc.
Just another way to look at it.
Posted: August 2, 2009, 12:13 pm
by Evil86saleen
Understood. If the 64 doesnt feel right I will expand my search for a F250 and see what i can find.
For some reason I want another 64. I like the look that I get from ford guys when they look under the hood and see the old Y sitting there and they have to ask what it is.
Not enough old school guys around anymore.
kyle
Posted: August 2, 2009, 12:28 pm
by cdherman
Greg D wrote:Both look like decent trucks for the money.
I wholley agree. $1300 for the 66 is a much better deal.
Posted: August 2, 2009, 1:25 pm
by Michelle
Back in the day I had a 64 F 100 with a 292 and a three speed. I had a two horse trailer and hauled my horses to rodeo's and trail rides with it and had no problems, but then I was at sea level too. However I did live in Colorado for a number of years at 9,000 feet. You can tune you 292 to altitude and you should have no problem. You probably wont be the first to the top of the mountain, but you will certainly get there. When I was living in Colorado I use to drive my 78 Bronco back and forth from there to Texas to see my mom that lived at about three hundred feet above sea level. I carried a small box with carb jets, timing light, distributor wrench and a couple of extra gaskets just in case I broke one removing the float bowl. I would stop about Dumas and rejet my carb up or down depending on which way I was going and do the same for the timing. The rule of thumb for timing is one degree per thousand feet above sea level past what ever the book says. I.E. if the manual for your truck calls for 10 degrees timing and you are going to be driving at 8,000 feet you would want to set the timing at 18 degrees. Also jet the carb with smaller jets for altitude, I found that to be a trial and error experiment. Also you may want to use a smaller power valve as your engine will not make as good vacuum as at lower altitudes. Of course this all does not matter with the newer computer controlled cars and trucks.
Posted: August 2, 2009, 4:07 pm
by Evil86saleen
Ok just got back from looking at the 64. I will start a new thread for that discussion.
kyle
brakes & gearing - go slower
Posted: August 3, 2009, 12:00 pm
by douglloyd
I built a '66 1/2 ton longbed to be a puller, but it does not work all that great. I pull a 16' dovetail carhauler - wood bed about 1600lbs. Very hilly in east TN.
My engine choice for better mileage was a 302, but for pulling I should have gone bigger. The two barrel Mcraft 2100 needs to go, but the intake mfold is for a two barrel carb.
I have the 4 speed T18 trans which is good for pulling. Also the longbed helps with trailer sway - a little.
Ditto what everyone already said about stock brakes. I am still running the drums on single pot M/S but they will not do the job. The trailer has electric brakes on one axle - but I am planning to add brakes to the other axle when I get time. I tap the trailer brakes to keep the load from pushing the truck, but not much more.
On the other hand, putting kickass power disks up front and expecting this to stop you is asking for trouble with a heavy load. You need to balance your braking in hilly areas and rely more on engine compression and lower gears to control the speed.
Mostly I tow with my '66 1 ton (dually flatbed) and although much slower (6 cylinder NP435, 45mph) the extra weight and the larger brakes make it OK even in hilly spots. I'm sure the truckers are not fond of following me up a hill at 40mph but I do eventually crest the hill.
Doug
Posted: August 3, 2009, 5:02 pm
by Thunderboy
I looked long and hard on a good Slick for towing my 18ft enclosed car trailer before I decided on a 66 F250. I agree about the brake upgrade first. I also use a weight distributing hitch with sway control and trailer brakes.
351W and a ZF 5-speed, because I like the control the trans gives while towing. An NP435 4-speed is an excellent trans behind an FE that usually comes with a 65-66.
I have personal experience with a 66 F100, 352, a C6 and drum brakes while towing a 2-horse trailer in Colorado near Durango. Never again.
