Help with my Ranger
Posted: August 9, 2009, 6:54 pm
by Fanatic
All of a sudden my 2.9 Ranger 1989 does not charge. Battery -idiot-light is on .
I have installed a new alt w/reg and battery, checked all connections, checked fuse panel under hood. There is no charging coming from alt. The main wire to the battery only has whatever volts is in battery. The "I" connector shows 2.9 volts and the "A" shows 5 volts.
I tried connecting 12 V to the "I" with no change.
What am I missing?
Any ideas?
Thanx
Posted: August 9, 2009, 7:05 pm
Tim, does yours have one of those cable ends on the starter switch that has the cable going into a pretty thick rubber insulator that is a U shape?
The connector inside those can break and screw up all sorts of stuff in the starting & charging system in these. I simply cut it off on all the Rangers, Explorers, & Bronco IIs I had (2-3 of each, lol) and replaced them with some real good cable rings. You check through the fuseable links in the system for continuity yet?
Posted: August 9, 2009, 8:05 pm
by 36truck
Check ground & cables for corrosion.
