When did 302/5.0 motor mounts change?
dotcentral
Post by dotcentral »
Well, this caught me completly by suprise. I wanted to install the 5.0 into my 66 today, went with my motor mounts over to the block, and suprise! There are no provisions in this 91 T-bird block to accept the older type motor mounts. How are people mounting these in the older vehicles? Is there a way to do it without re-engineering the whole thing, or am I stuck with an engine I can't use?
:cry:
bluebolt
Wrong mount
Post by bluebolt »
They never changed the 302 block as far as motor mounts, 2 vertical bolts about 7 inches apart. The mount you have has to be something other than a 302. Pics would help.
dotcentral
Well, I guess I have an oddball then.
http://fordtruk.com/forums/album_pic.ph ... ser_id=227
62galxe
Post by 62galxe »
no picture. ill try to get you a picture in the morning of a block i have.
1963 uni PATINA BLUE
1965 short bed
dotcentral
I fixed the link. The site crashed on me and I couldn't get back on it for about 30 minutes or so.
BIGTRIP
Post by BIGTRIP »
here is a 351w if that helps at all. truck mount still intact.
Being stroked is nice, but I would rather be blown!
62galxe
Post by 62galxe »
here ya go
1965 short bed
dotcentral
Those look different than the mounts on my 71, which has a 351W. the mounts on it look like, and I think can interchange with, the FE versions. I'll try to get some pics of it tomorrow so you can see what I'm talking about.
But I guess I'll hit NAPA up for a set like yours. What year truck did that come out of?
oldtrucks
Post by oldtrucks »
I have a set of mounts from a 91 Tbird and a bunch of 302/5.0 blocks I will take some pictures in the AM and post. I used the Tbird engine in my 86 Bronco with no problems. The Tbird mounts are different but bolt up to the block the same as all winsor blocks and the M blocks.
Mike Kincheloe
Mikes Old Trucks
I restore old trucks and cars
1950 F7 Cab and Chassis
1976 F150 4 Speed 4 X 4
1996 Taurus
dotcentral
Mike, I'd appreciate that.
The t-bird had mounts that are sort of "D" shaped 1/8" thick metal plates, and have a hole in them. No way this would work with the engine stands in my truck. I'll try to post a photo tomorrow.
If I could get a mount that would fit the towers, that would solve my problems, I think and hope. An application or a part number would be very helpful. And size of bolts to attach the mounts to the body would help. I seem to have lost most of those.
ABA
Post by ABA »
So there's not a threaded bolt hole here? (see arrow)
'01 F150 Lightning
490RWHP
Gas Mileage? What's that?
Jerry
62galxe
Post by 62galxe »
If you look up the tbird mounts I think what he has are the hydraulic mounts. They are cylinder shaped with a stud on the top and bottom. There is a plate bolted to the block for the mount to attatch to. Sounds like you just need to remove the plates on the block and install some mounts for a truck. 1969 to 1985 year model F100/150/250 if my research is correct.
Kenny
1965 short bed
ABA
Post by ABA »
Yeah those t-bird mounts are special made and they are proud of them too....If I remember correctly they run about 80 bucks a piece...I had to buy 2 of them when I did the V6 to V8 swap in the other '93 I had.
'01 F150 Lightning
490RWHP
Jerry
bluebolt
Mounts
Post by bluebolt »
Were you trying to use 352 mounts? No way they will work. Like others suggested you need 302 mounts for a 1969-1979 truck. You alos need the 302 truck frame stands, the 352 stands are about 1" higher and will cause problems with driveline angle and other issues.
bluebolt
Mounts
Post by bluebolt »
Check out this page from LMC, you can see the diiferent 302 and FE mounts.
http://www.lmctruck.com/icatalog/fb/full.aspx?Page=50
dotcentral
I thought the FE and small block were interchangeable, but I guess not. The mounts on my 351W sure look similar to the FE.
Anyhow, thanks for setting me straight. I'll have to buy a new set from the parts store.
TxSlick66
Post by TxSlick66 »
289, 302, 5.0, 351W, 351C all had same bolt provisions on th block. The rubber mount is different for TBird and Mustang and F-100.
TxSlick66
aka MustangSteve
Money you ENJOY wasting is NOT wasted money...
