automatic transmission options for stock 352
Posted: August 18, 2009, 2:38 pm
I have been looking thru the forum for a while to read about the best way to swap an automatic transmission for the stock 3-speed (with OD) my truck currently has.
I'm not necessarily looking to make the change, but I'd like to know what I'm in for if I decide to go that direction.
Is there a place or a posting on the forum that compiles this information?
Has anyone posted a photographic step-by-step instruction?
for instance, I'd like to know:
- what transmissions will bolt up to my stock 352? I've had cruise-omatics in cars (with 352's) before but I don't much like the cracked housing that results when you shift into drive from reverse while the vehicle is still in motion.
- does it necessitate changing my steering column if I decide to install a floor shifter for the automatic? Can I leave the original column in place?
- how would this affect the floor hump? do I need to cut and rebuild the hump to make room for the new tranny?
- I assume I'd need to shorten the driveshaft
- which trannys use a vacuum modulator vs. linkage? if I go with the floor shifter, it would seem that the vacuum modulator would work best since I wouldn't have all the shift linkage betwen the column and tranny.
- I also assume I'd need to swap out the radiator for one with a tranny cooler.
Any thoughts or advice from those who have changed over?
thanks![/list]
thanks![/list]
