gas blasting
Posted: September 9, 2009, 11:34 am
my friends idea, he rigged up a blow gun with a siphon hose attached works just like sand blasting except the siphon hose is stuck in a 5 gal can of gas.
worked great, really cleaned off the entire bare 223 block, did not use as much gas as you would think. after its clean, blow off all the remaining gas on the block/parts with air, dries right away.
make sure you oil the bores and other inportant machined surfaces right away or they will begin to rust.
best to do it outside and no smoking.
Posted: September 9, 2009, 11:45 am
by Max
Out at the base we had one of those metal, refillable pesticide cans with the pump spray handle on top. We would fill it with JP4, pump up the can and clean engines with it. Worked awesome!
Re: gas blasting
Posted: September 9, 2009, 12:51 pm
by Phil
ICEMAN6166 wrote:best to do it outside and no smoking.
really? :shock:
Posted: September 9, 2009, 1:32 pm
by Michelle
When I was younger I would have tried that method, but as I get older I get wiser and today I would be a little scared to try that with gas. I have heard of too many accidents where people were severly burned using gas as a cleaner.
Posted: September 9, 2009, 3:40 pm
by 1961 slickwilly
done it the other day and now i dont clean with gas when i was at work friday. the little nuts and lock rings used on 4wheel drive truck front ends. the first one sets your wheels bearings and has a tit then goes on a washer with holes in it that fit over the tit the the last nut goes on. We at work have probally two 5 gallon buckets of these all different types. well to get to the tell. we was running out of one type so i decide to cleann all of the buckets worth we had some gas so i went to cleaning poured the gas in one bucket dumped half a bucket of parts in to let them soke to get all of the grease and grime off. whil i'm letting them soke the phone rings i'm on the phone well my bosses dad walks in to use the chop saw and didnt cover the buckets or move the saw away from the bucket of gas and went to cutting. i hear a loud boom and walk out of the office to see whats going on. he used the saw which throwed sparks in the bucket which in turn ignited turnig our shop in to a fire ball. so i grab the fire extinguisher to put it out.(well my bosses dad also set our shop broom on fire the week before and put it oout with said extinguisher and didnt tell any one till now) the extinguisher was empty so i crank the pressure washer rite out side and went to spraying all in all shops still there soaked in water but standing the only real damage was the work bench
Posted: September 9, 2009, 6:12 pm
by Uncle Skip
Brian.
That is deadly on so many levels.
If you're going to do something like that, use a mixture of diesel and paint thinner (no, not naptha, not enamel reducer or laquer thinner).
Gasoline is deadly in any event. In a mist its subject to pyrophoric ignition, meaning it can catch fire without a spark.
Also, with it coming out of a nozzle at high speed, you have to consider static electricity build up at the tip. A small discharge will ruin your day.
The flame front will be everywhere the fumes are, and you're standing in the middle of the fumes.
Breathing concentrated gas fumes isn't any bargain either.
Please, don't anyone try this.
U@ss
Posted: September 9, 2009, 6:14 pm
by Uncle Skip
Max.
JP4 is not gasoline.
U@ss
Posted: September 9, 2009, 6:25 pm
by Johnny Canuck
Gas blasting? Sounds like a job for naked Joey :roll: :rotflmao: Bolt.gif
Posted: September 9, 2009, 6:29 pm
by ABA
Uncle Skip wrote:Brian.
U@ss
I thought about this the whole time I was getting that tar off my car yesterday with gas...I put the rags in a sealed container as soon as I was done.
Posted: September 9, 2009, 6:56 pm
by Max
Skip, who said it was?
Posted: September 9, 2009, 8:06 pm
by Michelle
When I bought my big truck it had lots of tar on the frame rails near the rear of the truck. I used diesel fuel to get it off. The diesel is about effective as anything I have tried for removing tar.
Posted: September 9, 2009, 8:38 pm
Michelle, you now have me wondering how diesel would work on undercoating - hmm.
Posted: September 9, 2009, 11:34 pm
by 61 Merc
ABA wrote:I thought about this the whole time I was getting that tar off my car yesterday with gas...I put the rags in a sealed container as soon as I was done.
Also be careful about the container that you put gas soaked rags into as they can spontinaneously combust. It should be a sealed metal can.
And I agree that you should not use gasoline for cleaning, had a friend using gasoline to clean off part of the motor, created a spark and got trapped under the vehicle getting severely burned.
Dean
Posted: September 10, 2009, 7:45 am
by slick4x4
ICE . i know some of us can get away with doing this...
i have used gasoline and diesel , starting fluid ect. ect for years.
never had any problems ever...
but i think its because we are ''out in the middle of no-where''
but as i have kids to ''teach'' now , i shy away from this practice.
mostly use the store bought cleaners & high pressure water.
i do understand where you are coming from, i too am a ''use what you got'' guy.
Posted: September 10, 2009, 10:38 am
by Phil
Relax. Ice is from Alaska where the deer and elk bleed gas.
Posted: September 10, 2009, 10:51 am
by jakdad
Maybe try oven cleaner.
Posted: September 10, 2009, 11:25 am
by DCarr
I've been using low-odor mineral spirits lately-seems to work as well as normal solvent, but
without the stink. :)
