Advice Needed - '98 F-150 8.8 Rear Axle Problems
Posted: September 11, 2009, 12:28 pm
At least this is a Ford!
My son's truck, which used to be mine, is a '98 F150 with 200K miles on it. Rear axle is an 8.8, code is S869C, a locking rear, 3.55 gears. About 5K miles ago, the spider gears lunched themselves. The ring and pinion looked fine, no scoring or chunks out of them, so we cleaned it out and put it back together. I did not remove any bearings, nor the center section. We only removed the spiders and the center pin (along with the axle shafts, of course.)
Unfortunately, I did not know how to reassemble the clutch packs, so I had to guess.
Well, the rear end is making a clacking sound now, especially under acceleration, and the fluid is full of microscopic shiny steel particles. The magnetic fill plug is covered with fine black hair!
I have a 3.33 open axle out of a '99, cost me $400 - the cheapest I could find. It has 66K on it, but was full of water, so the pinion bearing may have rusted some.
I could buy a new Traction Loc center section for about $275.
I could buy a set of clutch packs for about $120.
Both options would still require a full rebuild master kit with bearings and all, and someone to do it - since I do not have the tools or the knowledge to set up a rear end.
So - rebuild the existing one?
Or use the '99?
Any recommendations are appreciated.
Or use the '99?
