question for truck drivers
Posted: September 30, 2009, 4:16 pm
by 65f100_Thug
I got a different truck and want to pick you guys brain on how to shift it.
Ok, its a 379 pete with a 18 speed Eaton fuller with the 550 cat 270 rears I think. Ive driven for 18 years and drove lots of different big trucks but this is my first bonafied LARGE CAR. I honestly have never cared about fuel mileage.I know that sounds bad ,but Ive always been driving for someone who was screwing me over so bad that bought high priced fuel and hammered on it just for payback.
This guy I'm working for now has went out of his way to help me and I would like to return the favor. the freight shaker I was driving has a big Detroit with a straight 10 and it got about 6.5 mpg but I'm afraid this CAT is not gona do so good,unless I develop some good shifting techniques.
In high gear I think I'm only tacking something like 1100 rpms at 65 and it don't seem to lug it and I would guess I need to keep the RPMs down as much as possible.
Should i split the gears all the time or with heavy loads only?
Any way I take it you guys get the guest of my question so SCHOOL ME please.
Posted: September 30, 2009, 4:35 pm
Fuel mileage unloaded or even loaded will partially come down to how long you stand on the loud pedal in each gear. Can you run up without splitting the gears loaded light - sure. Drive somewhat conservatively splitting the gears - you'll still save fuel. Some of this also depends on the type of driving you do - are you local and spend alot of time in town? or do you long haul - if you long haul it won't likely make much difference anyway since you spend 99% of you time in the top few gears.
Posted: September 30, 2009, 4:57 pm
by 65f100_Thug
I typically do a 6 1/2 hour run grossing anywhere from 83 to 86 and 7 or eight hours back. about 1200 miles every two days with 300 or so empty.
Of course I travel at night and go through allot of small towns dodging scales.
thats the downside of this particular job. with the straight 10 I was forced to hammer on it to pull hills and such,but I feel like I may have a little more room to work with this truck. Oh Arkansas miles (HILLS) on the way out then southern Mo and Kansas and middle Oklahoma miles on the way back(somewhat lighter) 82 to 83
Posted: September 30, 2009, 6:03 pm
If you are running alot of grades the 18 will do better on fuel. Simply because you will be able to match the gear to the grade better rather than having to compromise on every one with the 10. The engine in it will play factor too of course though. You'll get used to the new rig and be fine.
Posted: September 30, 2009, 7:42 pm
by Michelle
With an 18 speed your splits are so close together that you probably wouldn't have to split even with a load except for may be in the two highest holes. Also that cat will produce gobs of low end torque. I would find the sweet spot and keep it at or below eighteen hundred RPM at cruise speed. That is an educated guess from Cats that we have owned in the past. I guess the best way is to run it and see what RPM is a comfortable range for it, every truck is different, even trucks that are specked alike can be different.
Posted: September 30, 2009, 7:47 pm
by Kid
Progressive shiftying will help alot. If you start in low and as soon as it is rolling pop it into the next one. Don't run the revs up in the lower gears and each gear run the Rs just a little higher than the one before it. When you get to the High side you should be running the Rs to the higher side of the limits. I know in the last 379ex I drove it had a 575 Cat and it helped alot to shift that way. And stay away from the Jake, a Jake being used when not neccasary will drink fuel for and no reason. A Jake should be set to only come on about 40mph as that is about what you need when dropping off a Mountain somewhere. Alot of guys run the Jake down to where it almost kills the engine and at some point it will kick the rods and pistons out the side of the block....................Kid
Posted: September 30, 2009, 9:21 pm
by semotrucker
I agree with Darrell...progressive shifting keeping the rpm's low will help with the mileage...will also help keep your driveline intact with that big kitty.
Cam
Posted: September 30, 2009, 10:27 pm
by 65f100_Thug
Thanks for all the input.
I really love this truck. The difference between one gear to the other is so slight thats what makes it easy to do the progressive shifting.
In the Freightliner you will be pulling a hill and have to wait till It has already fallen on its face to down shift because the difference between the gears are so great,by the time you down shift its time to do it again and your down to 40mph.
with the 18 speed as soon as the RPMs drop you can split then when necessary split back and drop a hole and keep up the speed. Most times only dropping to 15th or 14th and your speed maintains pretty good.
Up shifting is kind of another story because I have some seriously bad habits .
Like driving it like the old Detroits LOL hammer it to the floor and tach it out and shift and repeat.LOL
I just need to calm down and see how graceful I can go through them keeping the RPMS low like Darrell and Greg said.
I appreciate the rapid responses Its 10:19 pm and I only have a 3 hour drive to Tulsa Tomorrow so I'm gonna snuggle with Momma and try to become a kinder gentler driver at about 4am keeping the jake off will be the hardest because it just sounds so darn good:) PS If any DOT personal is monitoring this....Im NOT over weight tonight and will catch my logs up b4 I leave.
Byron
Posted: September 30, 2009, 10:38 pm
by 65f100_Thug
[I would find the sweet spot and keep it at or below eighteen hundred RPM at cruise speed. That is an educated guess from Cats that we have owned in the past. I guess the best way is to run it and see what RPM is a comfortable range for it, every truck is different, even trucks that are specked alike can be different.[/b][/color][/quote]
Oh ya I forgot 1500 rpms in the big hole is almost 80 mph like 77 mph
I think 1100 is about 65 or so the spedo shows about 2 to 3 mph slow according to the turnpike radar that warns you not to blow through the toll booth. It really sounds like its idling down the road at 65 It may get me in trouble!
I could be wrong at those ratios I have a terrible memory I can give a more exact reading tomorrow. Ill write them down.
Posted: September 30, 2009, 10:50 pm
by johnzmu
Get used to that cat and you should have no problem with 6.5 mpg, My pete has the c-15 cat, and I gross 102,000lbs hauling cattle, and I average 6.1. Welcome to the peterbilt club. Solid trucks ain't they
[albumimg]6506[/albumimg]
Posted: September 30, 2009, 10:58 pm
by ezernut9mm
never driven an 18, but the progressive shifting theory is the industry accepted way to good fuel mileage.
i've never even driven a pete, and to be honest, i don't want to, because if i am that means i'm not doing ltl anymore and i'm out on the road. lol. and that's not for me.
i have driven a couple of w9's and was very impressed at the ride quality and "solid" feeling of the tractors. make fld's seem cheap and cheesy.
shiny side up Byron.
Posted: September 30, 2009, 11:11 pm
by 65f100_Thug
johnzmu wrote:Get used to that cat and you should have no problem with 6.5 mpg, My pete has the c-15 cat, and I gross 102,000lbs hauling cattle, and I average 6.1. Welcome to the peterbilt club. Solid trucks ain't they
Thats what this is a C15 i couldn't remember. The guy I work for has two companies and only 4 trucks. one company is the freight shaker and thats it then 3 petes in the other. he can only keep 1 driver for the petes and the rest quit after only a couple months. Ive been solid for him for 3 years and decided that ,heck I should have my pick of the trucks since Ive been 50% keeping him in business to heck with the johnny come lately s, getting to drive the peter cars.
HEY CHRIS!!! my son wants to know when cheech is ever going to get done smokin that blunt. It cracked me up he just leaned over my shoulder and said that hes been smokin that for a few months
Posted: October 1, 2009, 8:33 pm
by Kid
I never drove a 18 spd or one of the C-15 Cats, I did drive a C-12 and got terrible mileage but it had low gears for off road work. My favorites were the 15 over with DR and 2 stick 5x4. I drove a 79 long Hood KW with a 3408Cat that was pumped up with the 5x4 behind it, that truck would flat fly down the road. I know the old PC and DI Cats were not noted for fuel mileage back then, I agree the only way to drive the old 71 and 92 Series Detroits was to slam your hand in the door before getting in to make yourself mad enought to drive it, the harder you hammered it the better it ran. I want to buy a old W900a to restore and maybe run it on a local rock haul around here, hire somebody to drive it part time...................Kid
Posted: October 1, 2009, 8:50 pm
by ezernut9mm
byron, he'll be done as soon as he can find his way off the i-10. lol
kid, i found an older w9 (round headlights)i almost bought once, this was when i was still truckin for myself.
i wanted something cool and older, but my partner talked me out of it. lol.
it needed everything but the body and drive train fixed. interior was shot, needed all new rubber, brakes gone through, exhaust, etc. it had the big cat of the day in it (i can never remember the old cat designation no.s).
i wanted it to look like this:
my dream hot rod big truck.
Posted: October 2, 2009, 12:00 am
by 65f100_Thug
Well guys (and Michelle)
I kept it under 1500 RPMs today all day and It worked really well.
I just have to get it through my head that I get up to speed as fast
doing the progressive shift thing as I do balls to the wall.
There was a few occasions where... I was gaining on the car in front of Me and the one behind Me was in the hammer lane,
gaining slowly enough to be there to keep Me from passing.
I had to drop a gear and hammer it to 85 and pass real quick in order not
to get shut down. But even at that its nice to be able to do that.
All in All it felt good to be doing the right thing and using the equipment
properly.Ill try and get her cleaned up and post a picture of her. I'm just so proud to be driving a first class ride. I told my English teacher that I was gona have a 100,000 dollar ride one day, without her class.
THATS WHY YOU HAVE SO MUCH TROUBLE READING MY BROKEN SENTANCES LOL
Chris heres a W9 I was trying to get my boss to buy for me. 20,000 with rebuilt cat!!
Posted: October 2, 2009, 7:22 am
by ezernut9mm
that's a good looking ride for that price.
Posted: October 2, 2009, 11:27 pm
by 65f100_Thug
ezernut9mm wrote:that's a good looking ride for that price.
yah cris he sold it a while back. It had custom burgandy leather interior,
with the sofa in the back. he had did the MAJOR rebuild on the big cat it had the 18 speed and came with all the flat bed equipment straps chains,coil racks, had those wheel balances on the front with the beads in them. had like new rubber.
If I had any credit at all I would have bought it myself. You can barley buy a mustang for that price. I see it once in a while Its pulling a refer.
The guy who had it was a owner operator who was very paticular about
everything and kept it maintained like a old fasioned trucker,Which he was about 68 or so and his wife has cancer and he was retiring to spend
more quality time with her in the last days. was good timing too considering how trucking has gotten the last few years.
Posted: October 3, 2009, 8:57 pm
by Michelle
I took my big slick to the tractor and truck show this weekend in Temple Texas. We got rained out today so I came back early. My 67 has a 220 Cummins, thirteen speed and 3:91 Rockwell rears. If you run it up against the governor it will run 80 MPH, of course with a 220 and a trailer behind, that is hard to do. I usually run it with the trailer in 8th direct (12th gear) That gives my 65 MPH @ 2,000 RPM. That seems to be the sweet spot for the 220. The old 220 does not like being lugged and looses torque fast below 1800 RPM, I usually always sift at 1800 when climbing a hill and if I am almost to the top I will let it ride down to 1700 in order to top the hill without shifting. Great big difference from the 3406B Cat motor we had in the LTL 9000. It made great torque way on down to 1400 RPM.
Posted: October 6, 2009, 12:13 am
by 65f100_Thug
I noticed that if I'm not running at least 65 in 18th it does lug. It feels like a drive line vibration but its lugging.Anything below 1300 I think is bad. The drive line is new and u joints and carrier bearing too. I know because a mechanic forgot to put the bolts in the u joint and My brother n Law threw the drive shaft out with me riding with him. cut brake lines at 55 and long skid marks. heres a pic. its a pretty common Pete not too many extra trinkets but I do like the bumper. Oh and the color LOL at least they'll see me coming.
Posted: October 6, 2009, 8:59 am
by Michelle
It is a good looking old Pete, no doubt about it. Drop a gear and run it is 17th and up the RPM a little. With the 18 speed the RPM probably wouldn't rise over two hundred RPM. Also I might add that lower RPM does not always equate to better fuel mileage. With the 220 in my big Slick. I was headed out of Amarillo one day going into New Mexico and was bucking a strong wind out of the west. I was struggling to maintain 56 to 58 MPH in 8th direct (12th) and riunning about 1800 RPM. I had the foot feed flat on the floor trying to maintain. I dropped to 7th over (11th) and easily maintained a steady 55 MPH @ 2100 RPM and was giving it very little throttle to keep it at 55. It increased my fuel mileage considerable. It is all a trial and error game as each truck reacts differently.
