351 ??
oldfordcoupe
351 ??
does anyone know off hand if you have to run a different timing cover if you swap over from a v belt to a serpiitein belt ??? i know the h20 pumps are different ??
I don't know about the timing cover but I would think that it is the same. You will need a reverse flow water pump with the serpentine belt. The belt goes around the opposite side of the water pump so it turns backwards.
Kevin
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
63 F100
- FORDBOYpete
I believe timing covers are same, since pump casting is the same as is the harmonic Balancer.
The difference in pumps is not size/shape but direction of rotation.
The impeller inside is what's different.
V drive pumps won't cool in serpentine applications as it wants to circulate coolant backwards.
It tries to pump coolant thru raditor, not Block & Heads. Without the
adequate & proper circulation thru Block & Heads, engine o'Heats fast.
FBp
FBp
Change is the Only Constant
Pumps
I have a lot of personal experience with small block Ford pumps and covers. So here is my opinon.
1. Oldfordcoupe, please post some more info about what you are trying to do. I need to know what engine/front cover you have now and what serpentine setup you want to run..
2. You can put a Mustang 1986-1993 reverse rotation pump on pretty much all 1966 to 1980's timing covers. The important thing is the new water pump has round holes in the back.
3. You are going to have to change the harmonic balancer out for a longer one to match the serpentine drive. You can't use the 5.0 one, it's 50 oz imbalance. You may be able to use a late truck 351W balancer, they never changed from 28 oz. I have not personally tried this yet.
4. Turning a SBF water pump in reverse will not reverse flow through the engine. The pump is a centrifugal taking water in towards the center and using centrifugal force to force it out through the outlet ports in the block. Effiency would be greatly decreased though.
The difference between the serpentine and V-belt front cover is the serpentine belt cover does not have a mounting for the fuel pump and does not have the oil dip stick located in it.
Dean
Dean
61 Mercury SWB Uni - Project
63 Ford SWB Uni - Parts truck
Covers
Here's a link to images of teh different timing covers. Notice only one is a true reverse rotation cover RTCF-351RF. http://www.allfordmustangs.com/forums/a ... -chart.jpg
You also have "short" covers used on 91-93 Thunderbird, 94-95 Mustang and 96-01 Explorers. They can only be used as reverse rotation.
oldfordcoupe
Setrpentine
Do you know what Serpentine setup you are going to use? I would suggest a 1990's truck setup, the V8 Mustang ones are harder to find and more expensive. I am fairly sure you will have to change the balancer to the late 351W to properly line up the pulleys.oldfordcoupe wrote:the engine that i'm going to use is a 72 eng. that i built up for my sons 64 fairlane that he does not drive anymore
cavinandpavin
cavinandpavin
