removing light switch
tomrooster
How do I get the knob off the headlight switch so I can remove the switch?1966 f100. thanks Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
- FORDBOYpete
On the top of the switch housing itself, up under the dashboard, is a Push Pin & spring affair. With the Battery Neg' cable removed, pull the knob all the way to it's outward stop, headlights on position.
Reach up under dash and with your thumb, or index finger, depress push pin, pull knob & SHAFT free of switch assembly.
Undo the retainer using a flat screw driver or if you have correct male spanner use it. Switch assy will become free from dasboard when retainer bolt is fully backed out.
Hope this helps ya out.
CIAO FBp
CIAO FBp
Change is the Only Constant
Thunderboy
I'm glad I found this thread, as I have to remove all of my interior knobs and such for painting the cab today...I thought I saw another recent tread about this, does anyone else have more info on removing all of the dash knobs? Thanks!
Drew
Drew
Drew
66 F250 Frame swap, EFI 408W, ZF 5-speed swap (still!) in progress
63 Falcon Futura EFI 331W, T5, but not much progress... Slicks First!!!
