I put a new vacume on my blasting cabinet!!
Posted: January 18, 2007, 12:41 am
by F-Zilla
I was running a 2 HP shop vac, I could barely see while sandblasting. Today I put a 5.5 HP shop vac on it and the difference was phenominal! Close to 100 more CFMs made a big difference in visability! The rust and crud is flying off all these slick parts!
Posted: January 26, 2007, 1:22 am
by 64 f100
I was given a blasting cabinet, but it needs gloves, and blasting media. So far, the only thing I can afford is sand. Otherwise it's gonna cost me about 100$ to fill this sucker up.
Posted: January 26, 2007, 1:28 am
by 64 f100
Forgot to mention I use electolitic rust removal. It's slow using a battery charger, but it works. I've got a manifold in my little tank right now. Put it in day before yesterday, took it out this morning, wire brushed the loose stuff off, and put it back in. Figure it will be done tommorrow, and I can do the other one. As long as your in no hurry, it get the job done. I keep something in ther all the time, as a general rule. Stuff that I will be using later or getting ready for a truck not yet started on. Costs hardly anything to operate.
Posted: January 26, 2007, 9:56 am
by JimDog
Rich,
Can you describe your setup? How does it work? I am not familiar with electolitic rust removal, but I have a battery charger, and a bunch of small, rusty parts. I'd like to give it a try - assuming you don't have to be a rocket scientist to set the thing up...
Posted: January 26, 2007, 10:45 am
by Max
Rich may have an easier way, but I had this bookmarked for awhile now and had to find it:
http://www3.telus.net/public/aschoepp/e ... crust.html
Posted: January 26, 2007, 5:12 pm
by F-Zilla
I did a google search earlier. It looks pretty simple, all you need is some rebarb, wire, some simple basic hardware, a plasic bucket or tub (depending on part size), a battery charger, aome Arm & Hammer washing soda and water. If you already have the battery charger, you could probably build one under 20 bucks. I think I'm going to give it a shot.
Posted: January 26, 2007, 7:00 pm
by 64 f100
2 bucks for the arm and hammer washing soda, some scrap steel for the anode, 5 gallon bucket , battery charger, some sater, and your in business. I use stainless scraps for anodes, seem to last longer. Hook the positive to the anode and negative to the part. stick the parts in the water, with a hand full of washing soda ( not baking soda ). Let it cook, take it out evey once in awhile and brush it off. repeat till your satisfied. Rinse off with fresh water, blow dry, and or dry it with towel. Make sure you coat it almost immediately with something. oil if nothing else. Cause it will start to rust again very quickly.
