question about a 60 f250 and hydrolic clutch?
- slickmainer
I was talking to a guy that said he had a 60 F250. He used it when he moved to Maine from Colorado in 2002, it has been parked since. He has started and moved it around a couple times a year since then, up until last year when the rubber parts of the brake lines and hydrolic clutch were found deteriorated.
He goes on to say that he had a new clutch put in in 2002. Does that mean the clutch he put in in 2002 has since bit the dust or am i missing something. He also said that he added a 1 1/2 inch I-beam was added front bumper to rear, this is a very heavy duty frame. why would that be needed?
any help, thanks
any help, thanks
--Gregg--
you can't get there from here
a hydraulic clutch works just like your brakes do...
when you push on the pedal , fluid goes thru a line , down to a slave cylinder
this is what moves the clutch plate VS a mechanical clutch that uses a rod from the pedal to the clutch
they are easy to rebuild / same as rebuilding your brakes
the clutch itself may be perfect... but the master cylinder and slave cylinder may have to be rebuit... my 2 cents
Pat is correct. sounds loke the rubber hose for the clutch is shot.
as to the i beam, who knows what may have been hauling in the truck maybe worried about bending the frame.
- slickmainer
thanks for the input. I put a WANTED add in craigslist for a 59-66 F100 or F250, for free-$100. I got a reply. The truck was a New Mexico state work truck and he says its in really good shape. 69 390ci, 10ft flat bed with utility boxes on each side, ladder rack and step bumper. I'm gonna go look at it soon. A slick would be nice but they are few and far between up here, and people want a mint for them.
--Gregg--
For 100$ and it already has a 390. Sounds like a heck of a deal, especialy if it is from the southwest. Hydraulic clutches on those trucks worked better than mechanical linkage. Smother and cab rot and body sag did not affect the workings. Rubber hose may have to be made. You can make one from tubing, but you need the flexible hose for body rock and frame flex. You can find new master cylinder and slve cylinder on Ebay quite frequently. I saw some on there a couple days ago. I have purcheased two sets to have on hand when I catch some for cheap.
- slickmainer
- Johnny Canuck
- slickmainer
- slickmainer
well i don't have it yet. but I hope to by months end.
anyone know whats going on down around the steering column going through the floor. it looks like the hole has be cut out using a can opener.
the 390 was rebuilt in 98 and has 20,000 miles on it but it's been off the road for close to 6 years. He moved it around the yard for the past 6 years a couple of times a year, but that stopped last year, so i guess it's been sitting for just a year and half probably.
--Gregg--
Just a guess but do you suppose someone tried to change out the steering box by pulling it up thru the cab. Doesn't that year truck have the smaller steering box that is attached to the colunm?
