It is the easy things that get hard, WHY?
Posted: November 17, 2009, 12:10 pm
by Brian Taylor
Just a bit of a rant. I have been collecting all the things I need to put on a dual res on my stock drum drum 66. Yesterday I had all but the light switch ready and put it all in. Later that evening my wife helped me bleed the system, in the cold, but it never would keep pressure. The pedal would fall the first stroke and then be rock solid. Wait 5 seconds and the pedal would fall like a rock then be solid again. This morning I got out the old brake vacuum pump and mason jar combo and started to solo bleed the brakes and just can not get any improvement. I have went through all the fittings and made sure they were tight. I do not see any leaks even though I have fluid all over everything from the line mods.
I have worked on brakes a million times but this is piston me off. I will tackle it later after I add the switch.Just had to take a break and vent.
Posted: November 17, 2009, 12:17 pm
by Kid
are the shoes adjusted correctly.
Posted: November 17, 2009, 1:51 pm
by PFM-64f100
I had that problem before. Turned out one line wasn't tight enough and started sucking air.... grrr that line. good luck.. you watching this thread Gary (truckRat)?
Posted: November 17, 2009, 2:21 pm
by Brian Taylor
I tild you Chris I hate too many connections. I am going to try them again and check them for leaks. Also I just gave blood to the Slick gods. Putting in my micro switch for the brake light, now working, the wrench slipped and I opened up the end of my pinky finger. Typing is not good but I need the time to warm up and think.
The last thing I want is to take Gary to Smithville in a 68 Mustang Convertible people would point and stare.
Posted: November 17, 2009, 8:06 pm
PFM-64f100 wrote:I had that problem before. Turned out one line wasn't tight enough and started sucking air.... grrr that line. good luck.. you watching this thread Gary (truckRat)?
been there, done that.
forgot to tighten down the fuel line in the top of a gas tank once too. new fuel pump would not pull gas past the air leak.
now im always rechecking stuff.
Posted: November 17, 2009, 9:27 pm
by ezernut9mm
after reading this, i can't wait to start on my brake conversion.
Posted: November 17, 2009, 9:35 pm
by Obsa
Just remember, Murphy was an optimist! :lol:
Posted: November 17, 2009, 9:54 pm
by Paul Merrell
Do you have the rod for the brake master adjusted properly.
Posted: November 18, 2009, 7:08 am
by Phil
I've had reman master cylinders blow out with the 1st pedal press.
Probably not it but look for a wet firewall inside and out
Posted: November 18, 2009, 2:16 pm
by PFM-64f100
You get the new MC working yet? If so where was your problem?
Posted: November 18, 2009, 6:13 pm
by Brian Taylor
I am very ill with the flu or death something like that I feel like doo doo.
I am going to go thru all line connections after I clean all of them with brake cleaner to check for any leaks.
I think I have a problem with the plug I was using for the extra line removed going to the rear brakes. Not sure but I am going to medicate myself and climb under the truck tonight and see what is what.
My thing is I have worked on cars since I was 14 I am now 48 and I still get upset when working on them, I should just roll with the punches.
Excuse me while I go pee again.
Posted: November 18, 2009, 7:48 pm
by Obsa
Brian,
Sorry to hear that you are ill with as you said "the flu or death". The H1N1 flu is serious not your regular seasonal flu. You should check and see if you are having the symptoms and if you are seek medical attention! I am not saying you have it but better safe than ...
You mentioned using a plug to cap off a unused line are you using the proper threads for a flare connection I have seen (actually done it myself too) people trying to use a pipe plug and it won't seal properly.
As far as getting upset when working on cars I have been there and done that too. Usually happens when trying to meet a deadline, like after dark on Sunday when I needed the car to drive to work in the morning. If possible just work on something else or clean the shop or reorganize your toolbox. Refreshing beverage of choice helps too.
Take care man
Posted: November 18, 2009, 8:19 pm
by Brian Taylor
I used a bent over and gllue filled piece of old line I removedd. It shows no sign off leaking but I am not taking anychances. I willnot get to in tonight my have has medded me up amd I am tired.
Tommorrow I will take all down and recheck all lines and I diid look for leaks form the new Mcc but it seamd dry, I have hasdtaht before.
thanks for the help I will report tommoreeow.
brian
Posted: November 18, 2009, 9:27 pm
Brian Taylor wrote:I am very ill with the flu or death something like that I feel like doo doo.
i did away with that connection,you only need a coupler for the back line and use the tee on the front.
if you get the 5 way connector from a 67-72 you dont have holes to plug.it has 2 holes for incoming lines, 1 out to the rear and 2 for front.
Brake lines
Posted: November 18, 2009, 11:01 pm
by Truckrat
Man Brian, What a bummer. So I am supposing the old single pot worked just fine didn't it. Trying to upgrade is a great idea and is much safer in case of a failure. After our conversatiion the other night you were all pumped up about doing this. Betcha it is something real small. Not the most fun to track down either. Hope it goes well for you and you feel better by saturday. Gary (TR)
Posted: November 19, 2009, 8:35 am
by Brian Taylor
I will get on it today. Gary I would hate to have to take you to Smithville in the 68 Mustang Convertible. Might just upset my wife a little too since it is her car.
Mustang Vert
Posted: November 19, 2009, 12:10 pm
by Truckrat
I know how it is with the 'wife's car." I was driving my explorer when she had the grand prix, and when it had a little problem she made me give her back the explorer so I get to drive the GP until she is convinced it is fixed and ok to drive. Then I'll get my explorer back. Meanwhile I drive it every day and it keeps going. I'm driving it to Haslet friday, and then to your place saturday morning. I ain't scared.
But if it quits on me, then I can rub it in about how I could've driven the Explorer and not had to worry about how I was going to get my car home from Texas. I don't think she thinks about that. TR
Posted: November 22, 2009, 8:40 pm
by adrianspeeder
It'll feel better when it stops hurtin'...
Adrianspeeder
