late model camaro front ends
truckerdaddy66
thanks for the replys,I think I will just have to buy one and check it out,I have done the nova graft on a 51 cheby pu,I like the straight frame rails on the ford.looks like shouldnt have to cut up frame any other than fabbing upper A frame mnt. from tubing,k member should sit on bottom of frame rail and remove fac. crossmember,this should get someones noodle going, cut weld ,cut weld
camaro front end
this is the front end i have decided to put on my `63. my next project, maybe 12-18mos from now. if you get it going, keep us posted. i`d like to see it. i`m in lake jackson (near you). jack
