Stainless Steel Exhaust for 223ci 1961 F250 Unibody?
olliesshop
Post by olliesshop »
I'm restoring my 1961 Uni that's been in the family since new. I'd like to put stainless steel exhaust on it, but I've looked in all the catalogs/internet sites I could find to no avail. Anyone know of a source for stainless steel exhaust for the 1961 223ci F250. I'd like something that replaces the stock system, with little tear up if possible.
Thanks for any help.
Tim - 1961 F250 Uni
F7BIGJOB
Post by F7BIGJOB »
welcome.gif to the site-from Ro Diland [R.I.]
And .....we want pictures :!: -Steve.
F7BIGJOB
-Steve
1965 F-250 4x4 Flareside
Uncle Skip
Post by Uncle Skip »
Nice idea.
Expensive, but nice.
You'll need to find a good muffler shop and see if they have or can get the stainless pipes.
Or have them estimate what you're going to need and get it from someone like Jeg's.
They do have an upgraded aluninized muffler pipe that lasts at least 4 times what the regular cheap ones do.
You might consider that, cheaper than stainless for sure.
U@ss
olliesshop
Thanks for the help / alternatives. I was thinking there might be an existing kit out there, like for other cars I've restored. The aluminized version also sounds like a good idea.
Thanks again :D
Tim - 1961 F250 Uni
Worst comes to worst you may be able to have a steel one ceramic coated. I bought one from Mac's years ago for a 64 with a 223, the fit was perfect.
Garbz
Post by Garbz »
Typical shop build of a stainless system will run well over $1500 if it is fitted and TIG welded. Mandrel bending on the stainless can be tricky and most shops may not attempt it.
Speedway and others sell 304 tubing and u bends. Be prepared for the cost.
Garbz
64 F100 Christine "Heartless" and Mean.
63 F100 Uni Custom, Cammer. T56 Low and fast. Still under the Knife
69 M250 Crew Cab 4x4, 472 EFI, Ranger, CC, Long bed
05 Escape.
All Ford and nutthing but Ford.....
Tech
Post by Tech »
Mandrel bent thick wall aluminized tubing has lasted 25 years on my motorhome and still looks pretty good. I also used a heavy duty welded truck muffler from walker.
It has a low rumble loud idle but quiets down once you start turning a few more RPMs.
Tech
olliesshop
Potential solution with Waldron's Anitique Exhaust
I mentioned this to a friend of mine and he mentioned this place ... http://waldronexhaust.com. It looks like they have an exhaust system for just about everything.
Specifically this one looks like it will work for my Unibody ... http://waldronexhaust.com/shop/product_ ... ts_id=3754 for $440, which doesn't seem that bad for stainless.
Hope this helps.
Tim - 1961 F250 Uni
Gary Seymour
Post by Gary Seymour »
That's a pretty good price!
