Flareside hidden latches
ProStreet66
Post by ProStreet66 »
Anyone know the best hidden latches to use? Or has anyone made their own? Any ideas? Thanks for any info.
Anthony
Post by Anthony »
Image [albumimg]8186[/albumimg]
this is how I did the Econo tail gate... picked up these latches from my local ACE hardware... they are spring loaded gate latches. I made a small latch for them to catch on then used a small chain to run from latch to latch on the inside of the bed... It worked for me and made the outside nice and clean...
Image [albumimg]8187[/albumimg]
A clean looking tailgate....
(click the small pic for a bigger pic...then click that pic for a jumbo pic....) I hope you can make out the latches in the pic.. :wink:
Truckfarmer2
Post by Truckfarmer2 »
A buddy of mine uses seat belt ends on the inside of the bed
slickmainer
Post by slickmainer »
chuck does this as well.
--Gregg--
you can't get there from here
ProStreet66
Great ideas. Thanks guys.
Uncle Skip
Post by Uncle Skip »
Merle.
How about the little rubber ball and stainless socket that some of the big rigs use to hold down the hoods?
I've even seen them on a few ATV's.
Seat belts tend to rub and ruin the paint
U@ss
semotrucker
Post by semotrucker »
I thought Merle was from Ohio. His truck is most definitely not a flair side unless he is working on something new.
Cam
slickmainer
super duper magnets? :?:
--Gregg--
ProStreet66
Im not Merle. Sorry for the confusion. It happens all the time.
prost66
Post by prost66 »
I am Merle, I made my own out of a 72 latch( whitch opens up and down) and mounted it inside the bed on a removable panel.Sir Micheals said it couldn't be done ,because the tailgate is too thin,that was enough of a challenge,it can and was done. I had to shorten the swing arms a little to clear the other side of the gate, but the original 66 rods were used and it works great,I used the seat belt latch on the 62 uni-cab,but i didn't like as well.Both gates I then reskinned the out side smooth.There are pics. of both in my album. Sorry I didn't notice the flareside title.I made a spring loaded latch for one, sort of like a inside house door sliding latch,only I made a new tube and spring loaded it. Worked well.
1966 F-100 "Grabber Blue" Pro St. [ 99 to 44/100% pure recycled FORD ]
ProStreet66
Hi Merle. My name is Rick. Thanks for the door latch idea. That is what Iam going to do. That should work out great.
