Clifford intake is on
Posted: June 15, 2010, 9:38 pm
by Brian Taylor
I finally got around to putting on my Clifford intake for my 300 engine. I will take pics when I finish the install. I have to reroute the stock accelerator cable and work out the exhaust sytem.
Can not wait for a drive.
Posted: June 15, 2010, 9:40 pm
by slickmainer
please do, I want to replicate your set up. I'd get that one for sale in the listings but it's too far of a drive
Posted: June 15, 2010, 9:44 pm
the stock cable is too short.
i used one from an 80s ford truck, slightly modified but has worked fine.
Posted: June 16, 2010, 7:15 am
by Brian Taylor
I thought it would be too short but with the carb I have I just need to make an "S" shape and bracket to keep smooth bends. Later if I get a chance I will try and get a linkage type from a newer model and use it.
I will put a pic in my profile later today showing the cable set up.
I did forget to get on important thing though, an air cleaner!
Posted: June 16, 2010, 8:06 am
by PFM-64f100
I can't wait to see it in person.... :D
Posted: June 16, 2010, 3:55 pm
by Von Dud
Thanks Brian - please keep us posted. I have the Clifford setup all in boxes and (intake, headers, 390cfm holley) and have been collecting related parts, re-routing existing systems in prep for the job.
Feels like a lot to chew off so i bet there may be a lot of folks with questions. Pictures would be great and thanks again for letting everybody know how you're doing!
Posted: June 21, 2010, 10:21 am
by My1stSlick
Now we just need to find you a proper carb to replace that $5 swap meet special you found! Congrats on the progress and I can't wait to hear it run again.
Posted: June 26, 2010, 2:11 pm
by Brian Taylor
I added pics to my album of the clifford and exhaust and the routing of the stock accelerator cable. I worried the cable would be stiff but it moves very freely. The only thing left now is to hook up a hot air tube for the choke or find an electric and swap it out(preferred).
Posted: June 26, 2010, 2:30 pm
by Michelle
It looks good Brian. Quite impressive looking.
Posted: June 26, 2010, 2:59 pm
by lastwagen 66
Brian,
That's looking good :thumright:
How's it running with that setup?
Carl
Posted: June 26, 2010, 3:16 pm
by Brian Taylor
It has a little bit more grunt off the line and I have been still setting up the carb. It has a pair of 50 jets in it and seems a good size for my set up.
It is a bit more impressive with the hood open than with the stock 1bbl set up.
If anyone is in need of a stock intake exhaust and carb for a 240/300 let me know.
BT
Posted: June 28, 2010, 2:54 pm
by My1stSlick
After seeing it in person, I can say it really enhances the engine bay. I especially like the custom exhaust mod. Truely inventful! Good job buddy.
Posted: June 28, 2010, 2:55 pm
by My1stSlick
Posted: June 28, 2010, 3:38 pm
looks good
you were able to use the stock cable because the carb is in the normal position where the carb on my wifes is sideways-must be the adaptor.
one issue i see is no heat to the intake, this will cause icing of the carb if you drive it in colder temps.
Posted: June 28, 2010, 5:51 pm
by Brian Taylor
Being in Texas the colder days are like your hot ones..
I think that will not be the issue with the split cast exhaust rather than headers.
Clifford intake is on.
Posted: June 28, 2010, 6:19 pm
by Unibodyguy1
Brian,
have a friend here locally that has this setup in a 54 F100 with a T-5, it flys and get 23-25 mpg on the highway with stock 3:92 gears.
Michael
Posted: June 28, 2010, 7:58 pm
was not really that cold when it happened 40* outside. got about 25 miles @ 65-70 mph then seemed like it ran out of gas. the whole intake was covered in a thin layer of ice up to about 1" way from the head
melted off quick when i shut it off and the heatsink started.
had no problem after i put copper tubes in the heater hoses and clamped them to the bottom of the intake.now it starts up real good in below 0 temps when its plugged in as the intake and base of carb is heated.
