Ford 8n
Congrats! on the new toy.
- ezernut9mm
almost sounds like it's low on fluid. i can't remember if those run off the trans fluid or not, but i think they do.
Could be the lift piston worn. I had a 8N about 30 years ago but had to let it go because of money issues (two kids, house payments etc.) I would like to find another prices on them are all over the place. these guys can provide info
http://www.mytractorforum.com/forumdisplay.php?f=38
- Alan Mclennan
what about the pic`s Tom!
- olliesshop
Is this what it is? ... Pretty awesome, reminds me of my Grandpa's '30's something Ford Tractor he had at the farm.
http://www.chatstractors.com/1362_ford_8N_tractor_.htm
Tim - 1961 F250 Uni
Yep, that is an 8N. the easy way to tell an 8 from a 9 or 2N is by the back wheels. rhe 8s have the small bolt center studs where a 9N and 2Ns have a much larger bolt center. Also the 8s have a 4 speed trans while the older models have a 3 speed
I have been wanting an 8 or 9 N or a Jubilee for a long time and just putting it off, I guess I am going to have to jump off the deep end and buy one, so I can haul it to the cars shows. I do attend a tractor and truck show every year in Temple Texas.
Michelle
- ezernut9mm
don't get a 9n. those front distributors suck. i don't know if it was an early/late change over thing or if they all had them, but the fan likes to eat plug wires.
Early 8Ns had the front distribitor too made it a pain to install or set points. Pertronixs has a fix for that! Your right if the plug wires weren't properly routed and secured the fan would eat them!
- Roger Carter
The later 8N's had the side mount distributor. Not sure when they changed. My neighbor has a late '52 8N with the side mount dist (the last year for the 8N) and my son-in law has a real early 48 (first year) with the front mount.Obsa wrote:Early 8Ns had the front distribitor too made it a pain to install or set points. Pertronixs has a fix for that! Your right if the plug wires weren't properly routed and secured the fan would eat them!
My neighbor installed a 6 volt Pertronix in his 8N a couple years back. Starts first time, every time. It did with the points, also.
Sure are a lot of differences for being all the same.
Roger Carter
- ezernut9mm
just like slicks! when i first got into these trucks i had no idea just how different each year was.Roger Carter wrote:Obsa wrote:Early 8Ns had the front distribitor too made it a pain to install or set points. Pertronixs has a fix for that! Your right if the plug wires weren't properly routed and secured the fan would eat them!
Roger Carter
there was a company in Coffeyville Ks. that made a V-8 conversion....
started back in the .... 1950s ?
it was the FUNK conversion... could put a flathead Ford in them
knew a guy that had one , never saw it run though
- ezernut9mm
slick4x4 wrote:there was a company in Coffeyville Ks. that made a V-8 conversion....
those bring big bucks now a days.
- Roger Carter
I saw a V8 conversion at the Spokane Washington Swap Meet a couple years back. Something didn't look quite right. After a second look, I saw it was a V8-60, the baby flathead. It was a very clean looking conversion,slick4x4 wrote:there was a company in Coffeyville Ks. that made a V-8 conversion....
Roger Carter
