Magnetic starter wiring.
Posted: March 10, 2007, 9:47 am
by btalley
Hello All,
I'm replacing a 3 phase motor with a single phase and got a magnetic starter for the single phase motor. I have a wiring diagram with very little information. Does a magnetic starter only use the two hot legs and no ground? Thats what it looks like and this kinda makes since if you think about it. I think I got the starter figured out, now on to the pressure switch.
Thanks for any info.
Posted: March 11, 2007, 7:30 pm
by castruck_1964
btalley
not quite enough info but here it goes. hook line side to line terminals. hook motor wires to load terminals. connect pressure switch in series with coil on magnetic starter.
coil connections depend on coil voltage
If coil and line voltage are the same onside of coil hooks directly to line terminal other side of coil get power from pressure switch and other side of switch is connected to other line terminal.
Hope this helps you. you use the pressure switch to control the coil no motor current passes though the pressure switch just the coil current . magnetic starter controls motor current
Thanks Castruck
Posted: March 12, 2007, 7:33 pm
by btalley
So does anyone know, before I spend the time wiring up the motor correctly. Can you directly wire a non capacitor start motor just to see if the thing works?
Posted: March 13, 2007, 8:41 pm
by castruck_1964
btalley
the answer to your question most times is yes.
the only time the answer is no is on a series wound motor requires load or it will runaway and destroy itself.
these motors are extremely rare in larger sizes and have a commutator and brushes IE most power tools.
so unless your motor has brushes you should be good to connect it to proper voltage and turn it on for a test.
