what rims fit a 65 f250?
Posted: August 15, 2010, 5:59 pm
by notdunyet
Hi guys & girls! I just picked up my new toy, a 65 F250 Camper Special, and it has old tires on the original split rims. One tire leaks. What I'm wondering is, will the stock steel rims from my 86 F250 fit? I saved this old girl from the scrapyard, buying it from the original owner, and after sitting 20 yrs. fired up after filing the points and changing the fuel pump! Gotta love the ol' 352s! Anyway, appreciate any help! Thanks!
Posted: August 15, 2010, 8:09 pm
by ezernut9mm
yes, they will.
Posted: August 15, 2010, 8:12 pm
by fire truck
Actually, they may not. I have a set from a 88 here that won't fit my 61 or 66 f250 because the centers are too small to fit the rear axle centers....
Posted: August 15, 2010, 8:14 pm
by ezernut9mm
ah, that is a possibility.
Posted: August 15, 2010, 9:42 pm
by factorystock
These are the wheels you need if you want to be period correct and run the original caps. These were the standard one piece F 250 wheels, the 2 piece were the heavy duty option. Image
Posted: August 15, 2010, 10:10 pm
by Obsa
RE: What rims will fit my 65 f250?
Posted: August 15, 2010, 10:12 pm
by notdunyet
Thanks for the info, guys. I guess i was more concerned with the lug size, more than anything. The 86 lug nuts are bigger looki.g than the 65s. Guess I'll have to see by just trying. Thanks again!
Posted: August 16, 2010, 9:47 am
if you change the lugs. the factory ones are too short.
Posted: August 16, 2010, 9:56 am
by fire truck
You mean studs?
Posted: August 16, 2010, 10:10 am
fire truck wrote:
You mean studs?
yes.
Posted: August 17, 2010, 10:24 pm
by Unibodyguy1
I have some off of a 97 F250 4X4 bolted up with no problems.
Michael
Posted: August 21, 2010, 9:12 pm
by jcd302
I've got those wide ones off Frank out in the lean-to you can have if you want. Check out the ones on the 75 frame as well, but I think 1 is wider.
Posted: August 22, 2010, 3:23 pm
by 6166 Junkyard Dog
I Would be sure they fit the backs first since the rear axle on the older trucks have a bigger hub, then also Ford had 2 wheels the one in the picture is with a raised lip and the others had no lips at all trucks had the same rear bolt circle up to around 1997 but that does not mean they will fit and also some on way later years went to a Metric lug patterns
