Great way to start a restoration project
Posted: August 16, 2010, 5:57 pm
I recently inherited a very old friend a 1966 f100. This truck was bought on a special order by my grandfather. Unfortunately he passed away in 1970 and my father then bought the truck from my grandmother, then a month ago I got it from my father. It is almost a completely bone stock (other than the stereo, secondary gas tank, and the rims) 300 I6 with 4 on the floor and the 3/4 ton limited slip rear end.
The truck has lived almost its entire life in northern Nevada, so very, very little rust is on the truck. After spending 3 days washing and waxing the truck to get most of the oxidation off of it it is now as the pics appear
here is a link http://www.photobucket.com/greeneyedmnst
There are a couple of things that I really need to get ironed out in this old girl. I have found a problem with the truck back firing through the exhaust when down shifting. With that I checked for an exhaust leak and found a pretty major one coming from between the intake and exhaust manifolds. I am also on the hunt to see if these trucks came with "high altitude jets" for the carburetor so that I can get them swapped out for low altitude jets (since the truck now lives in California) If anybody out there could help me find this part you would be a god send.
I also plan on doing the following up grades
-Ignition system (either Pertronix unit or MSD have not decided which)
-Disk brakes all the way around.
-moving the gas tank from inside the cab to under the bed.
-removing the secondary gas tank
-removing the camper shell
-Electric radiator fan.
-HID head lamps
-Rewiring the entire electrical system with new wire.
-All the factory trim re-chromed and the Grill chromed since it has the aluminum grill right now. Not sure which is best way to go on the grill. Getting it chromed or just buying a new one.
-Replacing the Tailgate and repainting the truck its factory color. Which it is still factory paint on the truck
Any help that you guys could be would be of great assistance.
-HID head lamps
