Weight station
Posted: August 21, 2010, 12:00 pm
by aarons428
I will be trailering my slick to slickstock and am wondering about the weight stations on I-680 and I-80 on the west side of Iowa. Do i need to stop and what will they look for if i stop. This is my first time pulling a trailer on the interstate. Or how can i avoid them.
Posted: August 21, 2010, 12:06 pm
by ezernut9mm
no. you are not commercial and probably won't look the part either. roll on aaron, roll on! lol they won't even look twice.
Posted: August 21, 2010, 2:18 pm
by Anthony
with with Ezer... I drove down to Sevierville Tenn. with a trailer and trailered my Econo back with no problems.... I say truck on by them and they won't even take a second look at you either....
Posted: August 21, 2010, 2:26 pm
by Michelle
Chris is right, blow the weight stations, especially if you are towing with a pick up. I on the other hand sometimes go in and other times I blow them. It just depends on the state and how I am feeling. This time up I will probably go around most of them. It is harder when you are driving a truck that was once a commercial vehicle, there is a stigma attached that says to the scale master that you are commercial even though I have antique plates. It is hard for some of them to get over the fact that you are no longer commercial. I have personally been blessed and never called in. I have friends that drive similar trucks to mine that has got tickets for infractions that are usually reserved for commercial vehicles even though they have antique plates. So if it is not to hard to go around the scales I do, if there is not good way to go around them I will either blow them or go into them.
Posted: August 21, 2010, 3:02 pm
by ezernut9mm
the only time i would stop in a pickup would be if it had a company name on the side or a dot number. other than that, you are private and they aren't concerned with you.
Posted: August 21, 2010, 5:32 pm
by 62galxe
I couldnt stop. My 18' trailer is only liscensed for 3500# gross. Its cheaper that way.
