Blended fuels, ethanol, methanol
Posted: March 20, 2007, 5:27 am
by 64 f100
I was reading a Bass book and ran accross a short article on what these fuels mean to a boater. Looks like a real problem for older boats and not much better for newer ones. What concerns me, are some of the same problems involved with boat motors apply to cars and trucks as well. So I figured it would be good to start a thread here, for a discussion on what to do and what not to do, and how it affects what we do with our trucks.
These are things the blended fuels have affect on to the best of my knowledge.
Varnish will be disolved picked up and deposited in other places.
Fuel lines may or may not hold up with use of these fuels.
Original fuel pumps and carburaters won't last long with these fuels, so don't use NOS nor any older products when rebuilding these parts.
My personal experience shows that high performance engines do not like this stuff at all. Lots of knocking and pinging. Older vehicles don't have knock sensors and computers to retard timing when this happens.
I have limited knowledge and only personal experience to go from, so I welcome others knowledge and experience on the matter.
Posted: March 20, 2007, 5:52 am
by Horsepower
I've used the 10% blend for as long as I can remember. Support the farmers I figure. I have not had any problems with it and I use it in everything I own even my outboards.
Outboards have high compression and need octane. I use 104+ in all my outboards and it makes a world of difference, noticeable difference even. Every customer that comes into the boat shop is told the same thing. They have all said they notice a difference using it.
Now for the new E85
I've been using it in my 1888 Pontiac Sunbird for 6 months (3500 miles) with no fuel failure so far. I have noticed that the 33 mpg I'm used to getting is down to about 28 and it does not start as fast as it used to but I know it needs a tune up as well, so next week I will tune it up and see if the starting issue clears up.
I figured the car is old and used as a backup so I have decided to use it as my test subject. If it fails there is no loss to me so I will keep using the E85 till it does.
Posted: March 20, 2007, 6:57 am
by Ford4jack
I've had problems with it on fuel lines in chainsaws.
No problems in vehicles yet but I have been told these fuels tend to collect moisture
Posted: March 20, 2007, 7:23 am
by ghostflamed66
I have used 10% in my trucks and my fairlane. The fuel will soften the power valve and the other rubber components inside the carbs.
Also, i work for a JD dealership and the operator manuals on all the hand held products and mowers tell you not to use blended fuels. I have seen alot of cainsaws and weedeater fuel lines and the inside of the carbs turn to soft jello. Also saw a mower fuel cap that it softened the seal ring on the fuel cap.
Wes :oops:
Posted: March 20, 2007, 12:58 pm
by Slick Fan
I've noticed that methanol mix tends to harden up fuel lines prematurely on some of my cars. I don't have actual proof, but I think it's done the same to a few accelerator pumps too.
It would be nice if you knew exactly what sort of rubber you were buying in a carb kit, as to whether or not it will hold up to alcohol conditions...without waiting to find out later.
Posted: March 20, 2007, 2:20 pm
by Johnny Canuck
I'll tell you what it did for every single Slick with a 6 in it at Slickstock last year... cleaned out all the gunk out of the gas lines and plugged every fuel filter, ...so that the parts houses within spitting distance of the Hotel were all out of stock on said fliters!
Posted: March 21, 2007, 5:43 am
by 66fordtrucknut
Yep, That was my theory anyway at SS, We just switched over to ethanol blend then and talking to a guy fixing a gas pump and he was telling me how he's been going around constantly changing filters on the pumps, I couldn't believe how much crap came out of my carb the 1st day of SS, Actually limped there stalling out at every red light from the Md./Pa border. As far as boats go, the big probs are the ones with fiberglass tanks, something is reacting with the resin and unleashing a mess. I'm a Fabricator in a marine shop, so the new tank business was good last year.
Charlie
Posted: March 21, 2007, 11:00 pm
by 64 f100
The article mentioned the fiberglass gas tanks, but it also say it will lead to problems with aluminum also. It went on to say a lot more in addition to mentioning the tank issue, but without rereading it, I couldn't repeat it. It also said something about the water properties involved and what kind of issues this leads to with corrosion issues.
Posted: March 22, 2007, 10:03 am
Used to be said that the stuff (E10) was bad for rubber seals in the old carbs as was already mentioned. I used to run it in all my EFI delivery trucks and could swear they ran better, showed better mileage, and kept the fuel system cleaner. After all most fuel injection cleaners you pour in your tank are some type of alcohol. I always figured why not clean it with every tank while I save a few bucks. I have run several EFI vehicles with the stuff well over 1 or 2 hundred thousand miles with NO problems. I do NOT run it in my Slicks or my 85 GT which is also carburated, it gets Premium. I run Premium in the 05 GT because the mileage it gets on it balances the extra cost. From what I have been told (some years ago) new carb rebuild kits can be bought ethanol safe. I haven't had to rebuild a carb in over a decade so I really haven't checked lately on that. I don't know about new aftermarket carbs although I'm glad this subject popped up I will have to check on that.
Posted: March 22, 2007, 12:15 pm
by Slick Fan
Greg D wrote:I haven't had to rebuild a carb in over a decade so I really haven't checked lately on that. I don't know about new aftermarket carbs although I'm glad this subject popped up I will have to check on that.
Honestly, I haven't rebuilt one in a few years either, so the problem just may be fixed by now. :)
Posted: March 31, 2007, 5:03 pm
by shawns fords
ok, I have been running e85 in my 2006 F 150 it works great! because the truck was built to use it, I am saving up to 60 cents per gallon now and when reg fuel is running 3.00 a gallon this summer ill still be paying 1.99 as far as using it in other vehicles that do not have the proper setup for using ethanol you cant, the steel tanks will be damaged as well as fuel lines plus carb has to be built for use as well as injectors, the stuff is like running alcohol in a race car, which is another subject, I know several drag racers being as I do drag race my 06 until my 69 mustang goes back together and they all have made noticeable gaines running ethannol on the dynos over the past winter. im not a chemist or anything but what I have seen and my own experiences show me its a good product, I will not use it in my trucks but am seriously considering running it in my mustangs later on if I do manage to properly convert to ethanol prepped systems :)
