Page 1 of 2
Sway Bars
Posted: September 22, 2010, 8:04 am
by Blackwaterforge
Will sway bars from a 76 Ford pickup work on a 66?
Thank You!
Re: Sway Bars
Posted: September 22, 2010, 9:00 am
by randyr
Blackwaterforge wrote:Will sway bars from a 76 Ford pickup work on a 66?
Thank You!
Yes. I have one from a 76 F250 on my 66 F100.
Posted: September 22, 2010, 9:23 am
by Blackwaterforge
Thank You!
Posted: September 22, 2010, 10:44 am
by randyr
Be sure to get all of the brackets from the donor. I used the 76 radius rods, too because they are notched to hold the brackets in place.
Posted: September 22, 2010, 3:30 pm
by Hawkrod
Yes and no, fronts work but as mentioned you may need the radius bars. The rears for an F100/F150 will not as the later trucks have a wider frame. The rear F250 bars MAY work if they are from an F250 4X4 or CrewCab but if it is a regular F250 they won't work because they also have a wider frame. F350 rear will work. Hawkrod
Posted: September 22, 2010, 4:02 pm
by racerx1699
Does anyone have pictures of a sway bar installed on a 66?
Posted: September 22, 2010, 5:21 pm
by jakdad
Skip has done this and has a "how to" in here somewhere. Try a search. Good luck.............................
Posted: September 22, 2010, 5:28 pm
by randyr
racerx1699 wrote:Does anyone have pictures of a sway bar installed on a 66?
NOTE: The sway bar is installed upside down in these pics. Please scroll down for the proper installation. These pics still show the correct notch & pin in the radius rod & bracket. Sorry for the confusion!
Here are some pics of my 66 F100....as stated above, the swaybar is from a 76 F250.
I also used the radius rods from the donor truck because they are notched for the pins in the mounting brackets. If you look closely you can see the pins & notches.
Posted: September 23, 2010, 9:05 am
by matt2491
That looks good Randy. What size bar is it?
Posted: September 25, 2010, 6:33 am
by DV65CustomCab
Has anyone notched the Slick radius rods? Or, can you cheat and cut the pins off?
Posted: September 25, 2010, 9:12 am
by Fanatic
Is it me or doesn't that sway bar look like it should be flipped over. The angle at the end links seems to be off---causing the bushings to be compressed oddly. Flipping it looks like the bar would be flatter at the ends. I dont have a twin I-beam but was just looking.
Posted: September 25, 2010, 9:29 am
by MadMaxetc
The bar should be fliped from that picture.
Posted: September 25, 2010, 10:09 am
by randyr
MadMaxetc wrote:The bar should be fliped from that picture.
LOL! Well, how stupid am I????:oops: LOL! I'll flip that around and it'll probably work better......guess I should have taken pics of the donor truck.
As for the pins on the brackets, I don't think cutting them off would be a good idea. It would probably allow a lot of movement of the bracket and defeat the purpose of the sway bar. But then, of course, that's coming from the guy who apparently put his sway bar on upside down so do what you want... :shock: :lol: :lol:
Posted: September 25, 2010, 11:25 am
by Gritsngumbo
jakdad wrote:Skip has done this and has a "how to" in here somewhere. Try a search. Good luck.............................
Skip's sway bar install is for a straight axle truck (61-64)
Posted: September 25, 2010, 4:14 pm
by Fanatic
Wasn't trying to say anything bad Randy..............just an observation. Post some pics when you flip it, and besides it should work better and be tighter in the corners.
My seeing it was due to me putting an aftermarket (63 Impala) bar on the front of my Uni and having to make and adjust the brackets and the mounting. And good use of urethane ---thats the way to go
Posted: September 25, 2010, 5:58 pm
by randyr
Fanatic wrote:Wasn't trying to say anything bad Randy..............just an observation. Post some pics when you flip it, and besides it should work better and be tighter in the corners.
No worries, I didn't take it bad at all. I just felt kinda stupid that I hadn't noticed it when I put it on a YEAR ago!! LOL! I flipped it over this morning and will post new pics in a few minutes. Thanks for pointing it out. :)
Posted: September 25, 2010, 6:09 pm
by randyr
Ok....here's how the sway bar is supposed to look! :lol: :lol: :lol:
Posted: September 25, 2010, 9:40 pm
by Fanatic
:D Ahhhhhhhh, much better :)
Posted: September 25, 2010, 10:01 pm
by randyr
Fanatic wrote::D Ahhhhhhhh, much better :)
Sooo much better!! It's the little things that keep us humble right? :)
Thanks again to you & Dan for pointing out the obvious....
That was probably also contributing to my irregular front tire wear.....argh!
Posted: September 26, 2010, 6:26 am
by Weedhopper
I recently swapped a 76 F250 sway bar on to a 65 F100. It bolted on using the 65 radius arms. Just measured and frilled for the center bushing brackets, and viola! it's on. Looks just like the pics here, except it is on right side up! :wink:
